Manual switch
Old Apr 22, 2011 | 08:09 PM
tjbagz's Avatar
tjbagz
Default Manual switch
I am installing manual fan switch and would like to know amp rating..... 10 ? 30 ?
Input would be appreciated.
Old Apr 22, 2011 | 08:22 PM
johnnymo63's Avatar
johnnymo63
2021 C4 of the Year - Modified Finalist
C4 of Year Finalist (appearance mods) 2019
You don't need that big of a switch. I would use a 30 amp relay and an illuminated switch to power the relay. That way, your fan would run from the battery, instead of through the switch.
Use 10 gauge wire from battery to relay and from relay to fan.
Old Apr 22, 2011 | 08:52 PM
rodj's Avatar
rodj
Stock fan setup already has a relay.
You just use a manual switch to operate that relay
Old Apr 22, 2011 | 10:10 PM
pcolt94's Avatar
pcolt94
You probably just need a basic 3 Amp toggle switch to operate the already installed relay.
Mine has been installed for about 6 years with no problems.
Old Apr 23, 2011 | 12:55 PM
tblt44's Avatar
tblt44
the fan switch is put on the ground and all it does is ground it out so the fan works.All you need is a cheap toggle switch wired to both relays not the a/c relay,to the switch and then ground it out.Go to Mid america and they have instructions on what wire to hook up to.You justr got to put a hole thru the firewall.
Old Apr 23, 2011 | 04:34 PM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
Anyone have pictures of this done?
Old Apr 23, 2011 | 04:36 PM
tblt44's Avatar
tblt44
yep give me a few to get them together and I will post them
Old Apr 23, 2011 | 05:10 PM
tblt44's Avatar
tblt44
Location of my switch
Location where I came thru firewall
Hooked up to relay.Hook to the blue on one relay and the green on the other.Ya it looks bad but it works
To Manual switch
