Hyperchip?
Old Apr 22, 2011 | 09:13 PM
1986c4BrownMetallic's Avatar
1986c4BrownMetallic
Default Hyperchip?
I was looking to add a bit of performance to my 1986 c4. I was thinking about ordering the hypertech power chip and the high flow throttle body air foil from corvette central.
Any recommendations/suggestions would be greatly appreciated.
Old Apr 22, 2011 | 09:43 PM
vetteoz's Avatar
vetteoz
Stand in gutter and set fire to you money ; car will go just as fast from your wallet being lighter
Read bottom of this link
http://temp.corvetteforum.net/c4/vader86/minormods.html
Old Apr 22, 2011 | 10:41 PM
Frizlefrak's Avatar
Frizlefrak
Save your money. You won't gain any power. I don't care what their ads say.
Old Apr 22, 2011 | 10:47 PM
Hogan's Avatar
Hogan
From: First to Sign Grumpy's Hat Only 53 miles from Hell
St. Jude Donor '06-'09-'10-'11
I had one once, all it did was trick the computer that TPS was WOT. The car did feel peppier, but my a/c shut off cuz it thought it was WOT. Plugged back in the factory chip and whalla the a/c worked.
Old Apr 22, 2011 | 11:11 PM
Frizlefrak's Avatar
Frizlefrak
Just mash the pedal to the floor. Same effect.
Old Apr 23, 2011 | 01:40 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
For starters, give up the idea that cheap bolt ons will make HP.
Start with a cat-back system.
A decent radiator other than OEM
Look for a piggy back ECM programable prom.
Later a cam.
Old Apr 23, 2011 | 09:52 AM
Muffin's Avatar
Muffin
Why do I get the idea no one here likes either the airfoil or store-bought chips?
Old Apr 23, 2011 | 10:07 AM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
Keep your money in your pocket. This subject has been discussed a million times on the forum. Use the search function and check out posts for mods that do work.
To Hyperchip?
