Steering wheel feed back
Old Apr 27, 2011 | 12:12 AM
Marv02's Avatar
Marv02
Default Steering wheel feed back
Just checking on rough roads CA Freeways I get Steering wheel feed back as in a vibration is this normal for the C4.
I have 16 inch rims 50 seires tires new bushings new shocks.
Not so bad you cant hold on to the steering wheel but you know it vibrating going down the road.
Old Apr 27, 2011 | 08:22 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
No, vibrating is not normal.
Sounds like an out of balance tire, or worn suspension parts.
Old Apr 27, 2011 | 09:04 AM
oldalaskaman's Avatar
oldalaskaman
if you're talking bout the 'washboard' on some of them, its normal. if it does it all the time its usually tire balance, Road Force balancing cures when regular balancing wont, spendy though
Old Apr 27, 2011 | 09:43 AM
Marv02's Avatar
Marv02
All the tires are new.
245-50/16
They have if I lucky 5000 miles on them.
Old Apr 27, 2011 | 10:45 AM
cv67's Avatar
cv67
St. Jude Donor '05
Check tire/wheel balance as said above, look into your rack and pinion too.
Old Apr 27, 2011 | 10:59 AM
5abivt's Avatar
5abivt
How new are the tires? I know after the winter season my Pirelli P zero Rossos flat spot from sitting and will vibrate for several miles before they heat up and it goes away. What tire pressure are you running? If your pressure is above 35 drop it to 30 or so and see if the vibes settle down a bit. Easy way to tell if the rims are warped or the combo is unbalanced.
Old Apr 27, 2011 | 11:24 AM
Goldcylon's Avatar
Goldcylon
X3
Check into the following
1. Road force balancing all 4 wheels
2. Balancing of all 4 tires
3. Axle hubs get the car into the air and grab the wheeks to see if they wobble and have play
4. Shocks, Rack and Pinion. bushings etc
Old Apr 27, 2011 | 05:33 PM
Marv02's Avatar
Marv02
I had the tires rebalanced and had the aligment done.
Drives great now.
Old Apr 27, 2011 | 07:47 PM
oldalaskaman
totally cool
To Steering wheel feed back
