Blowing fuses
Old May 7, 2011 | 04:28 PM
tehcarguy's Avatar
tehcarguy
Default Blowing fuses
Earlier today, I pressed the cool button, and when I did it blew the CTSY fuse. When I tried to put a new fuse in, it immediately blew it. I guess something is wrong with the wiring for the ac controls? I know some of the wiring on the car has been messed with by the PO who did a pretty poor job on some of it...
Old May 8, 2011 | 11:56 PM
jfb's Avatar
jfb
Either miswired or a short to ground. The CTSY fuse powers a lot of circuits, one being the heat/ac control assy. I'd first check with an ohmeter if the CTSY fuse goes to the controller and if it does, there will have to be something wrong inside the controller.
Old May 14, 2011 | 06:02 PM
richauto's Avatar
richauto
If everything was working before you pressed the cool button, try disconnecting the a/c compressor. May have a bad clutch coil.
Old May 15, 2011 | 01:22 PM
tehcarguy's Avatar
tehcarguy
I disconnected the module for the a/c and heat controls and it hasn't blown the fuse yet. When I had it plugged in, it would blow that fuse. So I guess I need a new one?
Old May 15, 2011 | 08:09 PM
Chuck Tribolet's Avatar
Chuck Tribolet
Could be a lot of things, the control module or something
downstream from that. Get an FSM and a multimeter
and start chasing the bug.
To Blowing fuses
