Electrical help
Old Apr 20, 2002 | 05:10 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Default Electrical help
Last week the car was broken into and the radio removed. Insurance is paying for the repairs, but I hold no hope that the shop has as much info as you guys.
Here is the problem:
No interior lights
Turn on the head lights (first or second position) and the digi dash goes dark, with the lights off its normal.
The light on the rearview mirror that is supposed to come on with the headlights does not come on. The light that is controlled by a switch works fine.
Biggest problem - the electonic ac/heat controls are dead. I mean dead, can't even get the vent to turn on
Any ideas as to what needs to be fixed? Will putting a radio in make it all work again? Change the fuses?
Thanks in advance :cheers:
Old Apr 20, 2002 | 07:20 PM
JonM's Avatar
JonM
Default Re: Electrical help (jaa1988)
If they ripped the radio out you can pretty much bet that other wires were pulled as well. All the wires should be checked to make sure they haven't been pulled or cut. There is a good chance there are fuses blown. You can easily check them just by looking at them. I wouldn't sign off with the insurance company untill it is fixed and you have used it for a good week. There is a chance one thing may be working fine untill you turn something else on at the same time and have a fuse blow. Pull the panel off the pass side door for the fuses, pull one at a time and look at it. If it is blown you usually will see a black mark on the inside of the plastic and the metal strand inside with be broken. Good luck
Old Apr 20, 2002 | 07:27 PM
Alchemist's Avatar
Alchemist
NC Events Coordinator
Default Re: Electrical help (JonM)
...I wouldn't sign off with the insurance company untill it is fixed and you have used it for a good week. ...
Ab-so-freakin-lootly right!!!! Make sure things are fixed to your satisfaction BEFORE you sign off...and that will take a little shake-down period. Don't sign NOTHIN' til then'cause they ain't gonna do squat AFTER!
Old Apr 20, 2002 | 10:08 PM
jaa1992's Avatar
jaa1992
St. Jude Donor '12
Are there any other fuses hidden away behind the dash?
Lots of good info, and I don't intend to let them off the hook until I'm happy with it.
James
Old Apr 20, 2002 | 10:57 PM
JonM's Avatar
JonM
james
There is one behind the Center infomation cluster...Its for the alarm system. There also may be inline fuses if it was an aftermarket radio. You may also want them to check the 2 cables that plug into the Dash Cluster, they may have been pulled loose.
Old Apr 21, 2002 | 01:21 AM
jfb's Avatar
jfb
Didn't your alarm go off when they broke in?
Old Apr 22, 2002 | 12:13 AM
jaa1992's Avatar
jaa1992
St. Jude Donor '12
Default Re: Electrical help (jfb)
If it did, it did not wake me up. I assume it did, I tested the system yesterday when I had the top off. Even though the "security" light isn't comming on it still works the way it was designed - open the doors without using the key and the horns sound. Its just the horns are not very loud, and I sleep real soundly.
I did see an air horn setup that might be loud enough to wake the dead though :jester
To Electrical help
