Oxygen sensor question?
Old May 14, 2011 | 12:23 PM
daddysvet92's Avatar
daddysvet92
Default Oxygen sensor question?
I have a 92 auto, and I took it for an emmissions test and it "failed" the NOx ppm.
My car did have a 64 code which I believe is a "lean right oxygen sensor"
First is the code 64 - a lean oxygen sensor?
Second will this effect my NOx ?
The Seven possibles are:
-Inoperative/ineffective EGR system
- Excessive lean air/fuel ratio
-Maifunctioning cats
-Excessive spark advance
-Faulty Thermostatic Air Cleaner system
-Engine deposits or mechanical defect
-Faulty cooling system
Any help would be appreciated!
Chris
