Head light bypass?
Old May 15, 2011 | 03:37 AM
Hendrick SS's Avatar
Hendrick SS
Default Head light bypass?
Is there a way to have just the marker lights come on without the head lights poping up?
1996 C4
Thanks,
Doug
Old May 15, 2011 | 04:49 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Unless I am misunderstanding your question, yes there is.
Just turn the headlight switch to the first position.
The "parking" lights will come on without the head lights coming up.
You can also turn the fog lights on with the switch in this position.
Old May 15, 2011 | 09:15 AM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Old May 16, 2011 | 01:09 AM
Hendrick SS
I understand that, but I don't want the headlights to flip up. They stay off, but they flip up in the 1st position. How do I keep them from flipping up?
Thanks,
Doug
Old May 16, 2011 | 01:56 AM
96GS#007's Avatar
96GS#007
Thanks,
Doug
Interesting. Guessing you have a wiring or switch issue. If you rotate the switch from "off" to the "Parking Lights" position, the headlights shouldn't rotate open.
Old May 16, 2011 | 02:02 AM
Hendrick SS
That's what I thought too, but they do. I will check the switch and see what I can find.
Thanks,
Doug
Old May 16, 2011 | 09:28 AM
RollaMo-LT4
They should not open if the switch is in the first position (parking lights only).
Off = headlights closed, all lights off
First Position = Parking lights only on, headlight doors closed
Second Position = All lights on, headlight doors open
Once the headlights have been turned on, then moving the switch back to the first position will turn the headlights off, but the doors will remain open.
Old May 16, 2011 | 10:22 AM
Y-ME's Avatar
Y-ME
Something wrong with your car in that case.
Old May 19, 2011 | 01:03 AM
DSmall's Avatar
DSmall
Cruising
Is it a canadian car with day time running lights?
Old May 19, 2011 | 09:39 AM
Goldcylon's Avatar
Goldcylon
Valid question. However if I may suggest you may want to install a DRL kit like I have. The turnsignals stay on as the markers. I love this mod
http://www.webelectricproducts.com/products.htm
Old May 19, 2011 | 11:49 AM
DSmall's Avatar
DSmall
Cruising
I would like to keep the headlights from coming on so soon. My car is from canada and the headlight pop on about 1 hr before sun set.
Old May 19, 2011 | 03:28 PM
bsmutz's Avatar
bsmutz
There must be a light sensor somewhere on your car that activates the lights. The sensor may be dirty or occluded from exposure to the elements, making the lights come on earlier than they would when the sensor was new (just a guess). With a little examination of the electrical schematic, you should also be able to bypass or disable the sensor and turn your lights on manually if so desired. Replacing the sensor may help with the early turn on.
Old May 20, 2011 | 02:08 PM
aklim's Avatar
aklim
Weird. Mine have NEVER done that. Parking lights is parking lights and no flipping up. I thought that Canadian ones are always on??
Old May 20, 2011 | 02:19 PM
DSmall's Avatar
DSmall
Cruising
The parking lights are always on, but when it gets a little darker out like late afternoon, the headlights turn. They turn on in the garage before I pull out also. Even had them come on will under a bridge waiting on a stop light. The eye is on the top of the dash in front of the steering wheel. It may be going bad, or this my just be normal. Just wondering.
Old May 20, 2011 | 02:41 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
headlight 001
Old May 20, 2011 | 04:07 PM
UNCLEBILL's Avatar
UNCLEBILL
If it is a Canadian car; you will see a flat round sensor on the dash above the gauges. Gently pry it out and you will see 2 wires. Put a 100 ohmn resistor in parrallel to the 2 wires and gently put back in dash.
NOW; you have complete control of your hd lites from the switch.
THIS IS THE STANDARD CANADIAN FIX
It works on my 1990 Vert.
Bill
OOPS...almost forgot...your hd lites will only flip up when you turn them on at the switch but you will always have daytime running lights during the day....
Old May 21, 2011 | 01:24 AM
DSmall's Avatar
DSmall
Cruising
thanks, I'll try it. It seems dorky with the headkites on and it is not dark, kind of like you don't knowhen to turn on your lights maybe you shouldn't drive a Vette, mabe a Honda.
To Head light bypass?
