need help , door switch
Old May 16, 2011 | 04:59 AM
Mohammed_z's Avatar
Mohammed_z
Default need help , door switch
is this the part that cause courtesy light to stay on ?
door ajar switch ?
the driver side is bad..do i need to buy only this ?
Old May 16, 2011 | 06:03 AM
VA50th's Avatar
VA50th
door ajar switch ?
...yes and yes.
Also check your dimmer switch that controls the courtesy lights. It may be pushed to the max position.
Old May 16, 2011 | 06:07 AM
Mohammed_z's Avatar
Mohammed_z
Originally Posted by VA50th
...yes and yes.
ok thanks.. the dimmir switch it's not to the max
I found the switch at tld-corvette cheaper than ecklers !!
I think they are different brand names
Old May 16, 2011 | 09:49 AM
VA50th's Avatar
VA50th
...something else.....
..if the switch is bad....the 'Door Ajar' warning will be lit on the dash, even with the doors closed.
To need help , door switch
