replacing weather-stripping
Old 05-16-2011, 12:11 PM
nintytwocorvette
Cruising
nintytwocorvette's Avatar
Default replacing weather-stripping
my car leaks in the rain at the two front corners of the roof. would replacing the weathers-tipping around the car fix this? and if so, what kind of adhesive is best to glue it with?
if there is a cheaper or more effective way to fix the leak, please tell
thanks
Old 05-17-2011, 11:37 AM
95fxdwg
95fxdwg's Avatar
Default Leaks
VERY CAREFULLY EASE EDGE OF SEAL OUT OF U CHANNEL (EITHER SIDE WILL WORK , AND PLACE VACUMM HOSE BEHIND SEAL AND TUCK SEAL BACK IN PLACE , MOST SEALS DO NOT REQUIRE ADHESIVE TO HOLD IN PLACE . THIS IS AN EASY CHEAP FIX FOR SOME LEAKS .AND YOU DO NOT HAVE TO REMOVE OR REPLACE THE SEAL , IT'S WORKED A HUNDRED TIMES FOR ME ON CUSTOMER CARS
Quick Reply: replacing weather-stripping
