Rear Deck Trim Removal..
Old Jun 11, 2011 | 04:41 PM
DA1984VETTE's Avatar
DA1984VETTE
Default Rear Deck Trim Removal..
Has anybody removed the 3 rear trim pieces, if so what is involved? It looks like the outer pieces are held by screws, but the center piece has the **** on it. Does the **** just lift up and off or how is the **** removed? Any help would be appreciated. Mine is in need of a repaint.
Old Jun 11, 2011 | 05:25 PM
Casket86's Avatar
Casket86
Old Jun 11, 2011 | 06:24 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
yank the **** off and loosen the screws.
Old Jun 11, 2011 | 09:16 PM
oldalaskaman's Avatar
oldalaskaman
**** is friction fit, gently pry it up or it will break
Old Jun 12, 2011 | 01:12 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Yep. The top storage latch has a ****/bar that pulls straight up. It is a fairly stout "pressure" fit. But, it will come off. I suggest some leverage IF you don't press down on the surrounding plastic in such a way to break it instead.
Besides that and the screws, you will need to pull the clips off your hatch lift. Prop the glass up with a broom or similar. Pull the hatch supports of their ball/socket joint. I suggest doing these one at a time.
You will find two other trim pieces hidden under the side pieces. They come out with 4 screws. They form the bottom lip of the privacy shade track.
If you also need to get the shade out, stick a flatblade screwdriver between one end and the side panel. Pry so the end shade is pressed inward -- much like a toilet paper roll spring works. IOW, spring pressure outward is what holds it in.
Old Jun 12, 2011 | 03:24 AM
DA1984VETTE
Thanks for the responses. I think this will get me started...
Old Jun 12, 2011 | 10:16 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
My fuzzy memory recalls there is a hidden screw behind cargo lights.
Old Jun 12, 2011 | 10:50 AM
jon0108's Avatar
jon0108
im not sure, but i think you might have to remove the hatch struts, at least the lower part of them, in order to remove the 2 side pieces.
Just seen Greggpenn's post
Old Jun 14, 2011 | 08:23 AM
VETTEDETTA's Avatar
VETTEDETTA
So the hatch supports are just a straight pull? No other tricks? Found i've got a broken right hand side panel
Old Jun 14, 2011 | 10:28 AM
Frizlefrak's Avatar
Frizlefrak
You mean the struts? Yep, they pop right off. If memory serves me correctly, use a small screwdriver and compress the release tab and pull them off. Just have a helper support the glass or use a sturdy prop. The glass is HEAVY.
Old Jun 14, 2011 | 10:58 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Yep, did that on my 96 last year.
Old Jun 15, 2011 | 10:05 AM
VETTEDETTA's Avatar
VETTEDETTA
Thanks, just the wisdom I was looking for
Old Jun 15, 2011 | 09:28 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Old Jun 17, 2011 | 12:31 AM
VETTEDETTA's Avatar
VETTEDETTA
I had a look at my strut today, couldn't find the release tab though?
Do you feed the screwdriver in by the balljoint bit?
To Rear Deck Trim Removal..
