Quick introduction
Old Jun 14, 2011 | 12:54 PM
Repoman1's Avatar
Repoman1
Cruising
Default Quick introduction
just got my wife our first Vette, 86' auto ...looking forward to dumping a bunch of money into it, which is expected. I have been in a few forums, and look forward to meeting you all. I can be mouthy at times , so just tell me to shut up if I get out of hand.
The person I purchased the car from stated that he had the plenum "upgraded" and had "larger" fuel injectors installed...but I noticed that the plugs look like they're frikin original (or atleast old)...so what would be the advantage of doing those things if everything else is stock?
Old Jun 14, 2011 | 01:04 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
Don't know why they installed bigger injectors, unless it's built, it's a waste of money.
As far as being mouthy, well many people on many car forums are always smarter than everyone else so you should fit in well.
Congrats on your car! They're fun. Don't let some of the wiseguys turn you off from here, it's a great place.
Suggestion! Stay away from threads that talk about who's faster. They never end well!
Old Jun 14, 2011 | 07:01 PM
blben4's Avatar
blben4
Congtrats looks like you will fit in just fine here!!
Old Jun 14, 2011 | 10:15 PM
John A. Marker's Avatar
John A. Marker
Welcome to the madness.
The upgrade to the plenum may have been simple....a little grinding to remove some of the restrictions inside. Post pictures of the engine, and we can tell you if it looks stock on the upper end. If the engine is stock...no advantage to using a larger injector. Even with some major modifications....no advantage to a larger injector.
Old Jun 15, 2011 | 12:02 AM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Welcome! Here's some great info on the L98:
http://temp.corvetteforum.net/c4/vader86/
Old Jun 15, 2011 | 01:02 AM
mike100's Avatar
mike100
more probable the injectors got replaced due to modern fuels being hard on the early cars- whether or not they are stock or larger is hard to tell, but 22 lb stockers are probably good enough to support 350+ hp anyways.
Old Jun 15, 2011 | 12:34 PM
j-vette's Avatar
j-vette
St. Jude Donor '10
Pix...?
To Quick introduction
