Water pump replacement 90
Old Jun 19, 2011 | 06:34 PM
auger58's Avatar
auger58
Default Water pump replacement 90
Any info I could get on getting the old pump off would be great.I got everything off but I it looks like the whole A/C bracket needs to come off,am I right. Also the fuel lines.
Old Jun 19, 2011 | 07:58 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
Looking at my 88 FSM the A/C brackets and fuel lines have to be disconnected.
Old Jun 19, 2011 | 11:46 PM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
I did the water pump on my L-98 when I had my '85. Followed the directions in my old Haynes manual. It's not difficult. Just take your time and you'll be fine.
Old Jun 20, 2011 | 01:02 AM
Frizlefrak's Avatar
Frizlefrak
I did it (actually, timing chain job) on my 84, quite similar procedure. The A/C compressor has to come loose, and has one hellaciously long bolt that's real fun to get to, but isn't a major undertaking. Fuel lines have to come loose.
Remember to bag and label all of your fasteners so it's easier to reassemble. The 84 had 4 different size water pump bolts and I believe the TPI cars do too, so it's important to label them.
Shouldn't take you more than 2-3 hours to change it out.
Old Jun 20, 2011 | 08:55 AM
WW7's Avatar
WW7
One important thing I want to add...Before disconnecting the fuel lines take off the gas cap, then release the pressure on the line by using a towel to soak up the gas and pushing down on the pin in the schrader valve ( located next to the Fuel pressure regulator/ has a screw cap on it ) If you don't release the pressure first you will get a gas bath..I have a fuel pressure gauge that has a gas release on it, but if you don't have one this is the second best way......WW
Old Jun 20, 2011 | 09:17 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Yes, you have to take the AC bracket off. AND you have to unscrew the two fuel lines to get the AC bracket off. The AC compressor can be removed an pulled aside without disconnecting the AC lines or discharging the pressure in the AC system. BUT you have to be careful not to break or crack an AC line.
As mentioned above, you must bleed the pressure out of the fuel system prior to removing the fuel lines. You can easily do this by removing the fuel pump fuse from the fuse box, and then start the engine. Run the engine until it runs out of fuel (30 - 40 seconds) and dies. This will get all of the pressurized fuel out of your fuel lines. The fuel pump fuse is clearly marked.
Old Jun 20, 2011 | 10:01 AM
auger58's Avatar
auger58
Thanks guys, I got it mostly apart fuel lines are still on and 1 bolt is not coming lose.tried WD40 is there anything else I could try?
Old Jun 20, 2011 | 10:18 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Which bolt are you talking about?
Old Jun 20, 2011 | 11:09 AM
auger58's Avatar
auger58
Gose form A/C bracket by belt tensioner back to the block, I can see where it bolts to in the back
Old Jun 20, 2011 | 11:39 AM
Frizlefrak's Avatar
Frizlefrak
Yes.
Old Jun 20, 2011 | 05:46 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Is this a Torx bolt? Is it frozen or is it just spinning?
Old Jun 20, 2011 | 10:10 PM
auger58's Avatar
auger58
It's a bolt with a nut and it frozen. A buddy told me to try freeze off, has anyone used it,
Old Jun 22, 2011 | 01:51 AM
HlhnEast's Avatar
HlhnEast
I would just about rather take an azz whoopin than change out a water pump on any car. Like said above you just about have to disassemble the whole motor to get to it. Take your time, mark every bolt, take pics if you need to. Its just tedious, not hard.
Good Luck!
Old Jun 22, 2011 | 04:06 PM
auger58's Avatar
auger58
I gave up put everything back on I took off & had it towed to the shop. $280 and they got it done in a day. That was worth the cost.Thanks for the help.
Old Jun 25, 2011 | 01:32 PM
Corvette505's Avatar
Corvette505
Dude, I took mine to a mechanic and had it replaced for $260. Inexpensive compared to the hassle of trying it yourself. It's one of the tougher things to replace, frustrating anyways from what I'm told.
Old Jun 26, 2011 | 11:37 AM
barney10mm's Avatar
barney10mm
I hope they replaced the crank sen. While apart . If same as my 93 .
To Water pump replacement 90
