Recommend brakes?
Old Jun 25, 2011 | 03:00 PM
MotorCity_87_C4's Avatar
MotorCity_87_C4
Default Recommend brakes?
My brakes are pulling to the left when I brake real hard. Original Calipers and hoses. Lots of pad left, no groves in rotors. Car has 164k miles hopefully they are not original rotors. Alignment is good and I replaced the bushings, tie rods and ball joints about 4k miles ago.
I don't do Auto-cross, just drive around town and maybe to a car show or to work. Would like to do front and rear calipers, rotors and hoses and pads. Can someone recommend a kit? Would like to stay under $700.
How are the brake bleeding kits? I remember as a teenager helping my brother-in-law bleed his brakes...until I pushed down too hard and gave him a face full of brake fluid.
Old Jun 26, 2011 | 12:14 AM
overdrawn's Avatar
overdrawn
here ya go....
http://forums.corvetteforum.com/c4-p...ices-ever.html
Old Jun 26, 2011 | 10:02 AM
c4zf6nut's Avatar
c4zf6nut
My advice would be to purchase caliper for the front right. You need to check brake pad width outside and also on the inside to figure out if the right front is lazy. If you are handy, it is easy to find repair kits for the calipers. If you are lazy, just get loaded calipers.
I would keep the rotors, maybe sand them (not necessarily turn them). GM does not recommend turning rotors.
In my case, I bought old stock Bendix rotors made in Canada/US just because all rotors you buy are made in China now. I prefer Bendix pads, but if the price is right and you can live with them, Friction Master pads made by Morse (OH) is good too. For my 89, I bought Morse pads for $10 for the front, even though I also have a set of Bendix pads ($40 on close out).
The Performance Friction pads need a bit to warm up.
http://www.rockauto.com/catalog/rafr...arcode=1041242
Old Jun 26, 2011 | 11:52 AM
Tony A.'s Avatar
Tony A.
Originally Posted by overdrawn
& only $180 for whole set
I just bought and installed some of these from BrakeMotive and I'm very happy. I took my 88 convertible out for a spirited ride late last night and sure enough a frickin' deer pounced in the road in front of me. I got an opportunity to try the brakes out for real and they did not disappoint. I had to change my shorts but that is beside the point.
If you have open rims, those that allow you to really show off your rotors and calipers, then you'll like the look too. Just be sure to ask for polished hats on front and rear to ensure they match in appearance. With this kit, some brake cleaner, some steel brushes, some plastic drop sheets, brake caliper paint and lots of patience and time, you can make them look awesome.
Old Jun 26, 2011 | 02:35 PM
MotorCity_87_C4
Thanks, I just replaced a set of Duracrap Pads on my other car, they squealed worse then a stuck pig. I rebuild calipers back in the day with guidance from someone experienced. I think I'd look at rebuilt calipers and new hoses on all 4 corners....I'm lazy in my old age.
Old Jun 27, 2011 | 07:51 AM
c4zf6nut's Avatar
c4zf6nut
Duralast would probably not sequeal if you had installed the shims or changed rotors. GM does not recommend turning rotor for noise problems.
However, to ensure that lifetime warranty they are hard brakes, and they are scary until you warm them up. (Silver) They are made by Morse which is a good company
The symptom you mention is also possible with a collapsed brake hose. My advice is to replace all brake hoses unless you know when they were changed last. I am still on my original brake hose . The shop told me it would be a waste of my money to replace them with the Bendix hoses I brought with the car.-)
It is always a good idea to flush brake fluid every two years or so. I would use Supertech DOT 3 brake fluid. ABS systems are very sensitive to water in the fluid, and the fluid is hygroscopic. I say DOT3 because it is slightly less hygroscopic and supposed to last a little longer.
BTW, you have a large budget. It would be best to replace calipers in pairs. My recommendation is to stick to the same brand of caliper.
Old Jun 27, 2011 | 09:47 AM
ks5shooter's Avatar
ks5shooter
St. Jude Donor '10-'11-'12-'13
x2
Old Jun 27, 2011 | 01:57 PM
c4zf6nut's Avatar
c4zf6nut
Motive Brake rotor kit is certainly is inexpensive. I think comments in this forum are very limited to the way the rotors look, not really the quality. Any rotor will be able to stop you, but you will have major issues when they start to crack, and other problems show up.
http://www.stangnet.com/mustang-foru...tmfw-rock.html
http://www.e46fanatics.com/forum/sho...d.php?t=712596
http://forums.corvetteforum.com/c5-t...e-package.html
http://www.aa1car.com/library/brake_rotors.htm
Old Jun 27, 2011 | 02:50 PM
pcolt94's Avatar
pcolt94
My brakes are pulling to the left when I brake real HARD. Original Calipers and hoses. Lots of pad left, no groves in rotors. Car has 164k miles hopefully they are not original rotors. Alignment is good and I replaced the bushings, tie rods and ball joints about 4k miles ago.
On those vintage vetts flex lines and clogged ABS units have been big issues. Although you don’t have the classic symptoms and it does not sound like the case, I would just keep in the back of my mind.
But what does come to mind as you say "brake real hard" are the rear brakes. They can make a car pull also and many people always assume it's the fronts. I would check out the rears for equal braking action before tearing into the fronts.
If you just change everything you indicated, it may just hit the problem. I think it can all be changed for under $700 but if the calipers are not leaking, they probably OK. I did rebuilt my old ones and is doable, but a pain getting seals and pistons back in. Mind did not leak nor did it improve the performance.
Old Jun 28, 2011 | 09:59 AM
c4zf6nut's Avatar
c4zf6nut
Checking rears is an excellent point, I will repeat: check inside pads as well as outside. If there is uneven wear, that caliper is lazy/stuck. It may work OK sometimes, and not OK some other times.
I repeat, flush brake fluid often. Does not matter what you use. Just make sure you flush brakes. Brakes and power steering fluid are the only things you should flush period.-)
Old Jun 28, 2011 | 05:49 PM
Tony A.'s Avatar
Tony A.
Had a discussion today about one-man bleeding systems. If you plan on flushing all of the fluid from the system, a one-man system may take a while as you can only get so much out at a time. Better off just opening the taps, have a friend pump the line to evacuate more of the liquid - much quicker. Be sure to keep the reservoir full to pull in the new dot3 while keeping the air out. There are plenty of DIY procedures for how to do it right. My .02
Old Jun 28, 2011 | 06:47 PM
MotorCity_87_C4
Maybe I'll show my son how to bleed the brake lines and not get his Pop's face covered in Dot 3.
Old Jun 28, 2011 | 07:05 PM
j-vette's Avatar
j-vette
St. Jude Donor '10
Quality time...
To Recommend brakes?
