Hey guys, need someone to set me on the right path here. I got my first vette 3 months ago, and still not driving it...ugh! I've learned alot here, but in reading the forums, I cannot find the answer for the TPS adjustment problem I'm having. Let it be known, as with many, my skills with electrical devices is lacking, but I was able to get a couple of paperclips into the top 2 wires (A&B) on the TPS wiring harness and check the voltage. I've read that the voltage should be .54, but I'm getting.24...about half what I need. I did start her up and check as well, but got the same reading. With the engine started, I can depress the TPS arm to get a .54 reading, but it's about half way through it's total motion to acheive this. There is no way that I can set the minimum idle speed that high to acheive the volatade I need...the TPS would almost need to point to the sky. However, when I depress the TPS arm while she is running to get the .54 volts...it sounds awesome!!! From what I can understand from the wire diagram, these wires run straight to the ECM...please help! What should I check here?
Jeff, I know how you feel about electrical things on these cars.
Connect your volt meter to the top two wires (where you have your paper clips). Turn on the key, but do not start the car. If your reading is .24 volts then you need to loosen the two torx screws on the TPS. You want them slightly loose so you can move (twist) the TPS up and down and it will stay in position....not hanging loosely from the screws. Now twist the TPS and watch the reading. Twist it until you get a reading of .54 volts. Now tighten the screws. Now if you take the throttle and open it wide open you should get a reading of 4.49 volts. Both of these measurements are plus or minus .075 volts. There is some play in the TPS slots so you can move it around to eventually get both of these readings. It takes a little trial and....more trial .
John, thanks. Indeed I have tried with no luck. With the TPS adjusted counterclockwise (to the fartherest position), I can only get the .24 volts. With the throttle wide open, I'm getting 1.3 volts. I will try again tomorrow, but again, the TPS arm had to be depressed half-way down to get the .54 volts...aarrgg! I did not see that the wires had fuseable links, or any way back to the fusebox, so I'm hoping (maybe) that someone has some fairy dust I can throw on the TPS and have it magically work.
Dog-gone-it! I just picked this one up from the dealer ($110 bucks), but you may be right. Do you know of a way to check it out to know for sure...or is that what I'm doing now?
Jeff
Reason: typo
Jeff
$59 Rock Auto for AC Delco, $17 for Airtex
Are both screws loose ? The whole unit can move back and forth and twist left and right. It takes the right combo of both to get the voltage you need.
Try it with your meter connected and see if you can get it to .54v.
Moving the TPS forward and rear did not produce any results. Indeed it is a "floating" mechanism, but rotating the entire unit counterclockwise to receive maxium voltage (depressing the TPS arm w/ TB linkage) leaves me with low voltage. As far as voltage to the TPS, do I unplug the TPS and just measure the top two wires, or find the "hot" and a ground? I feel so inadequate, my father would be ashamed!
Ok, just got back from testing. I placed one (I think it's called a prong) on the "C" and the other on either "B" or "A" and got 5.03 volts...WOOHOO! So, the TPS may be bad...dang-it!
