Sea Foam
Old Jun 29, 2011 | 04:45 PM
Biker's Avatar
Biker
Default Sea Foam
Someone suggested that I use Sea Foam to clean the injectors in my '86. Is this stuff safe? Does it work? Any precautions?
Old Jun 29, 2011 | 05:19 PM
F22's Avatar
F22
Not sure about the Seafoam. My fiance ran bottles and bottles of Techron through the Blue One (87') for years, with little difference in how it ran. I've gotta ask; have you replaced the stock factory injectors yet in your early C4? If you haven't, you might consider the FIC rebuilt injectors. It was night and day how the 'Blue One' ran after getting a set put in.
Old Jun 29, 2011 | 05:25 PM
shakedown067's Avatar
shakedown067
St. Jude Donor '12-'13
Love Sea Foam. I use it on all my cars and works great.
Old Jun 29, 2011 | 06:19 PM
astepup's Avatar
astepup
I buy it by the case for here on the farm....pour it into everything from the diesel engines to the lawn mowers. Never had an issue yet and we've been doing it for years. IIRC there was a thread about this sometime back and one of the answers was one can of seafoam every three tanks of gas. I've also heard Techron is good too.
astepup said that
Old Jun 29, 2011 | 06:27 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
When astepup talks, people listen........
Old Jun 29, 2011 | 06:48 PM
Eakster's Avatar
Eakster
Bought a can, then never used it. I only put Chevron (with Techron) in the Vette. Remember shoving a bottle of this up the CRX intake back in Blighty. Made lots of white smoke. Not sure if it did anything else. I ragged the **** of that car without mercy.
Any actual perceived improvements in performance?
Old Jun 29, 2011 | 06:57 PM
ks5shooter's Avatar
ks5shooter
St. Jude Donor '10-'11-'12-'13
Which line on a 93 do you put the seafoam in for the induction method?
Old Jun 29, 2011 | 10:07 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
I use the brake booster vacuum line.
Old Jun 30, 2011 | 01:19 AM
Pwnage1337's Avatar
Pwnage1337
Easy to get to. I usually stick a straw in the can of seafoam, then put the straw by the vaccum line so you don't have to pour the seafoam into it and spill all over the engine bay. Be DAMN SURE you don't let go of that straw though.
Old Jun 30, 2011 | 10:16 AM
Biker's Avatar
Biker
Thanks for the great feedback. My '86 has the original injectors. I'm going to add Sea Foam to a tank of gas and see how it works. Techron sounds like a good product, but it's harder to find at retail.
Old Jun 30, 2011 | 12:52 PM
aklim's Avatar
aklim
If you have the original injectors they are quite a few years old. Why rely on guesswork? Send it out to FIC to have them tested and cleaned. Why rely on these snake oils or "cleaner in a can"? Sure, they might do no harm but how do you measure the good it does? Huge cloud of smoke? Butt-O-Meter? Try cleaning a room in the dark. Yes, you have a pile of dirt but you don't know how much has been cleaned or how much is left. It isn't that difficult to take the injectors out. I do it every 3 years.
Only thing I use seafoam for is to stabilize the gas if I am storing my lawn equipment
Old Jun 30, 2011 | 01:14 PM
Biker's Avatar
Biker
I had the injectors professionally cleaned about 1.5 years ago. There's nothing wrong with the injectors, so I'm not inclined to remove them.
I think my problem is I don't cycle enough fresh gas through the injectors. I only drive about 500 miles a year. If the sun's shining, I ride my Harley.
Old Jun 30, 2011 | 01:30 PM
aklim's Avatar
aklim
What has the cleaning shown? My cleaning shows that it has crud after about 2-3 years. My diesel injectors get cleaned every 100K
I don't think that is so much an issue as long as you stabilize the fuel if you are not using it for a while.
Old Jun 30, 2011 | 05:06 PM
JrRifleCoach
I treat my Cherokee DD about twice a year. 1/3 can each in the gas tank, intake stream and crankcase. Engine seems to smooth out some and less lifter clatter for sure.
Not inclined to treat the Vette since she gets plenty of miles and lots of maintenance.
Old Jun 30, 2011 | 05:16 PM
Dudeurgettnavette's Avatar
Dudeurgettnavette
10yr Member and you dont know about seafoam!!!!
Old Jun 30, 2011 | 05:21 PM
aklim's Avatar
aklim
Maybe there is hope for him
Old Jul 1, 2011 | 03:15 PM
Biker's Avatar
Biker
Wise ***, I didn't say I don't know about Sea Foam. I asked is if it's any good. Your dumb *** comment lends nothing to thread, so go away.
To Sea Foam
Old Jul 1, 2011 | 03:49 PM
turbotim23's Avatar
turbotim23
I've read that putting seafoam in some year corvettes will harm the injectors. I believe it was true on my 93 year corvette for sure. It had something to do with the cleaner ruining o rings or seals in injectors on some year cars.
Old Jul 1, 2011 | 04:35 PM
aklim's Avatar
aklim
I doubt it does much more than harm your wallet. Certainly doubt it has ill effects on the injectors
Old Jul 1, 2011 | 07:35 PM
stoydido's Avatar
stoydido
[QUOTE=aklim;1578025001]I doubt it does much more than harm your wallet.
this comment from one who changes injectors on a 3 yr schedule? if they are getting that dirty so soon you should locate the root cause, because many original injectors run for over 100K.
I've not yet heard one other Vette owner say that cleaning injectors that often does anything more than give the owner a warm fuzzy, and lightens the wallet a bit. Sounds more sensical to add seafom, as Biker says.
"me new injectors are fine, but you never know unless you take them out and verify."
