1995 corvette problems
Old Jul 21, 2011 | 12:02 PM
besz28's Avatar
besz28
Default 1995 corvette problems
i have a 1995 corvette, at idle it has extremely rough idle, once car is driven engine runs smooth. when car is first started whole car shakes the idle is that rough. what do you guys think? Car has sat prior to this for 6 months
Old Jul 21, 2011 | 06:17 PM
Larry/car's Avatar
Larry/car
If it ran fine before storage I would drive it, see if it improves.
Old Jul 21, 2011 | 06:19 PM
gusgus's Avatar
gusgus
Could it be "old gas?"
Old Jul 21, 2011 | 06:20 PM
L82shark's Avatar
L82shark
St. Jude Donor '08
Get the old gas out and put some fresh stuff in would be my first thing. If it had ethanol in it and sat that long it has probably attracted some water. I went through those issues....
Old Jul 24, 2011 | 10:50 AM
richauto's Avatar
richauto
I had the same problem with my '94. When I put it away for the winter I filled the tank and added stabilizer. I had a rough idle in the spring and I added Lucas injector cleaner/lube and I haven't had the problem since. Hope this helps
Old Jul 24, 2011 | 11:35 AM
Frizlefrak's Avatar
Frizlefrak
I'd go as far as to drain the tank and refill with fresh instead of trying to run the old stuff out. Sounds like moisture in the fuel.
To 1995 corvette problems
