FM Modulator
Old Jul 28, 2011 | 10:29 AM
senter9's Avatar
senter9
Default FM Modulator
Hey guys I am going to install a fm modulator in my 93 corvette. Does anyone know the easiest place to intercept the antenna cable. Thanks
Old Jul 28, 2011 | 12:00 PM
Deepa's Avatar
Deepa
On your 93, im pretty sure the radio receiver box is behind the drivers seat under the storage bin. That would be the best place. You will need 2 adapters to go from the small gm connector at the box, to the large connector at the modulator, then from the large modulator fitting back down to the small gm fitting that will plug into the antenna.
