I'm changing my fuel filter and part of the procedure is relieving fuel pressure. All I got for now is the Haynes manual. It says pull the fuse for the fuel pump and start engine until it stops due to lack of fuel. When I pull the fuse, the engine won't start. If I put the fuse back, the engine starts and as soon as I pull the fuse it shuts down. The car has been sitting for over 12 hours. I assume since it's been sitting so long the pressure has been relieved and wouldn't start without pump pressure. Should the engine run a little bit after loosing pump power?
I probably should have just changed the filter and not gone through this procedure since the cars been sitting. Thanks.
If the car has been sitting I would have just opened the gas cap and released the pressure on the shraeder valve on the fuel rail.. This is the way I did my 89 and had very little pressure at the filter.. The method you discribe above is the proper one for these cars..Just wrap a towel around the filter as you unscrew the ends, this should handle the flow.....WW
Thanks for the reply WW.
I guess another question would be, should the engine shutdown right away when the fuse is pulled? It's like I turned the ignition off. Would it run for a few seconds?
