Wheels on "backwards"
Old Aug 20, 2011 | 04:16 PM
Jayhawk62's Avatar
Jayhawk62
Default Wheels on "backwards"
After reading about Cousar33's new Corvette and Keystring's advice about his back wheels being on backwards, I looked at mine; mine were also on backwards.
Discount Tire took off the rear tires and switched the rims side-to-side. I suspect that it was not Discount's fault that this happened. I think the previous owner had them on wrong and Discount just put everything back like it was.
I am learning a lot on the forum. Thank you.
Kistler
Old Aug 20, 2011 | 04:31 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
if you look at the back of wheel you will see its embossed left rear, right rear, left front, and right front.
Old Aug 20, 2011 | 04:34 PM
Jayhawk62's Avatar
Jayhawk62
Thank you for the information; like I wrote, I have a lot to learn. I just took a look at the angle of the fins....looks like they "bite" forward and pull outside air in.
Old Aug 20, 2011 | 06:00 PM
navy_vette's Avatar
navy_vette
The incredible 90's technology. They actually do a GREAT job at fighting brake dust. I think it's helarious when I see a brand new mustang with the front rims caked in brake dust after he cleaned them last week, then a C4 corvette with perfect rims and only cleans them when he washes his car.
Classic
Old Aug 20, 2011 | 06:04 PM
Railroadman's Avatar
Railroadman
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
Don't feel bad Kistler - we all start out knowing nothing, and the learning never stops. There was a thread a while back where guys admitted to discovering things they never knew about their cars, even after owning them several years in some cases. The great thing is that no matter what your question or problem, SOMEONE on this forum can help.
And in some cases, about the time somebody really has a handle on his car, he sells it and gets one older, or newer, and starts all over again!
Old Aug 20, 2011 | 06:06 PM
Jayhawk62's Avatar
Jayhawk62
I agree, Ford seems to have lost it; our 2003 Expedition really shoveled the brake dust out onto the rims....especially the front rims.....could not drive around the block without having to clean rims.
My neighbor bought the Expedition and immediately put on ceramic pads and that helped a little....very poor design. I think they fixed it in 2004 models.
Old Aug 20, 2011 | 06:24 PM
84wannabezo6's Avatar
84wannabezo6
Im pretty sure the fins are designed to throw the air out, the air goes into the brake disc near the center and exits the rotor on the outside edge
Old Aug 20, 2011 | 06:51 PM
Railroadman
My F150 and the wife's Jeep both have significant problems with brake dust. It may well be because I always insist on buying the cheapest brake pads they sell, rather than the "Lifetime Guarantee" type. My logic is SOMETHING is going to wear, and I'd rather replace worn out pads than rotors. Don't think I have changed the Vette pads since I've had it.
Old Aug 20, 2011 | 11:43 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
I could be wrong, but if you notice the expensive cars- BMW, Mercedes, etc there wheels always look dirty. I read somewhere that this is because they use a "soft" brake compound, This is so that the pads wear faster than the rotors. In the "Lifetime" pad compounds there seems to be a lot more metalics (SP?) in there. This causes the pads to last longer, but they eat your rotors.
Old Aug 21, 2011 | 09:17 AM
WW7's Avatar
WW7
If you want zero brake dust run Ceramic pads..WW
Old Aug 21, 2011 | 10:28 AM
motor city dave's Avatar
motor city dave
St. Jude Donor '16
I sold my 05 mustang bout 9 months ago.I never owned a car that produced so much dust, and had such poor stopping ability. I should say later model car.I had some when i was young i would have to throw out a anchor. lol
Old Aug 21, 2011 | 10:54 AM
Kmcoldcars's Avatar
Kmcoldcars
When I bought my 92 Vette the rear wheels were on backwards. Checking the paperwork I saw that the tires had been installed by Discount Tire in Phoenix, where I bought the car. When I got the car home to the Seattle area I called Discount to see how much they would charge to swap them around correctly. The answer was "Nothing. If Discount did it wrong we will fix it." Give your local shop a call. Let us know what they say.
Old Aug 21, 2011 | 11:19 AM
anciano's Avatar
anciano
Mine are on backwards, too, but I don't care because I'm dyslexic.
Anyway, if I'm parked in a row of other polo green convertibles with hardtops I'll be able to recognize my car immediately.
Old Aug 21, 2011 | 11:44 AM
Jayhawk62's Avatar
Jayhawk62
Discount Tires did the switch for me yesterday for no charge. Like I think I wrote earlier, I suspect it went in to Discount with the rims reversed.
Old Aug 21, 2011 | 12:54 PM
navy_vette's Avatar
navy_vette
I'll admit it...... this is a little difficult......
I climbed over the e-brake for 2 years.....
I layed the targa down in the back end because I didn't know what the brackets that were sitting in the cargo bin should be used for.....
I used a flathead screwdriver to unlatch the targa....
The targa has taken flight (I think this has happened to everyone) which I promptly fixed with duct tape.
Old Aug 21, 2011 | 01:01 PM
3D87C4's Avatar
3D87C4
Double check the tires are installed to rotate in the correct direction. It's possible the tires and rim rotation directions are inconssistent if the rims were installed wrong when the car went into the shop.
I think I read somewhere that the wheel fins on the earlier C4's weren't actually functional from an air movement point of view.
Old Aug 21, 2011 | 02:06 PM
Jayhawk62's Avatar
Jayhawk62
OK, in or out with the air....machts nichts, but should the fins, or whatever you call those "spokes" on the 1986-1987 corvettes, should they "bite" forward or reverse?
I would take off the wheels and look for the LF, LR, etc., designation but I gave away my torque wrench when I sold my Airstream
Not only that but I am basically lazy and they look OK now--all "biting" forward.
To Wheels on "backwards"
Old Aug 21, 2011 | 03:43 PM
3D87C4's Avatar
3D87C4
Yes, I think your wheels are correct now. Here's my '87 with the original wheels:
I've since switched to 17" rims. Next time you're near your car take a look at the tires. There should (I think) be a rotation direction indication (& it should be pointed forward ):
Old Aug 21, 2011 | 05:40 PM
Jayhawk62's Avatar
Jayhawk62
This (going right direction) is good to know By the way, your car looks like it could be parked in a beach parking lot in Ocean Shores, WA.
Kistler
Old Aug 22, 2011 | 01:10 PM
3D87C4's Avatar
3D87C4
It's Baylands Park in Palo Alto on San Francisco Bay.
http://www.cityofpaloalto.org/depts/...e_baylands.asp
The Lucy Evans Baylands Nature Interpretive Center is in the background.
It's a nice place for a walk by the water looking at the birds and small planes doing touch and gos at the adjacent airport.
