engine coolant fans not functioning
What temp did your cooling system reach when it overheated? If I recall correctly, for 1996 (with the air conditioner OFF), the fans don't operate at low speed until 228 degrees F.
What temp did your cooling system reach when it overheated? If I recall correctly, for 1996 (with the air conditioner OFF), the fans don't operate at low speed until 238 degrees F.
Compare the wiring colors in the diagram to the wires on your three relays to find which relay is number 1, 2 and 3.
Relay number one will recieve a ground on wire 335 (dark green in color) from the PCM when the temp reches 228 degrees F (this is how my '96 works also). This will cause both fans to operate in low speed. You need to determine if the relay number one coil is becoming energized when the PCM is allowing this ground. I did a voltage check on the left cooling fan wiring connector light blue wire to see if the contact was closing to power the fan at the proper temp.
You can follow the fan low speed 12 vdc power path from relay number one to the left cooling fan motor, through relay number three's 87A contact to the S123 connector, through the right cooling fan motor finally to the motor ground.
Above all, be safe when troubleshooting.
Long message, but I hope it helps.
Relay number one will recieve a ground on wire 335 (dark green in color) from the PCM when the temp reches 228 degrees F (this is how my '96 works also). This will casuse both fans to operate in low speed. You need to determine if the relay number one coil is becoming energized when the PCM is allowing this ground. I did a voltage check on the left cooling fan wiring connector light blue wire to see if the contact was closing to power the fan at the proper temp.
The FSM stated that the ECT needed to be replaced, but your suggestions are great and appreciate your advice.
