Headers coated or not
Thinking of getting long tube headers but not sure if I should spend the extra for ceramic coating or not, its for a LT1 and I have got to have them installed so money is a concern. I don't wont the engine compartment to get too hot to cause damage either. Thank you for your comments.
There is enough air movement to not do any dammage !
You should do a wrap on your starter for longer life !
I run TPIS longtubes but any with thick flanges that don't warp are good.
Yeah and they are powder coated with built 383 LT 4 and I have made long trips with no issues !
Also if you order your headers make sure they have the correct Oxygen sensor bungs !
I like what I've seen with the OBX option. Very nice workmanship for the price. The only thing yet to see is the longterm quality....
Per another poster in my linked thread:
Or, if cabin heat was too much, pull and coat them.
Or, if you didn't like the result for some other reason, resell them to the CF.
Kinda seems like a no-lose situation to me.
Cheap solution? You can get the uncoated headers, and keep the engine compartment at a reasonable temp.... I know a lot of people are going to yell and scream, but you can put some heat wrap on. It is NOT as efficient as ceramic coating, but it WILL help for a fraction of the cost. Here is an example.
I've also read where coated header owners have noticed their Jet-Hot in/out coated headers get cool to the touch before their plenum. Never tried it myself.
The big objection for heat wrap (that I know of) is if you start leaking oil past a gasket. That can soak the heat wrap and have heard stories of fire as a result.
