Is it common for corvette engines to run hot? I have just replaced water pump and thermostat and have been keeping an eye on temp gauge and noticed that needle is leaning to high end especially when car is not moving. (1996 41,000 miles)
Is this different from before you did the coolant change?
Did you use an LT1 stat?
Are you looking at the analog gage or the digital readout?
Are you running your A/C and what is the outside ambient temperature at the time of the temperature reading
Corvette C4s are designed to run at around 200F or more. The first fan is programmed to come on at about 229 F. Use your analog guage as an indicator only. The digital guage is much more accurate. Generally a C4 will run about 200 F when moving. When stopped in traffic the temp will increase to 229 F when the first fan comes on and cools it down some.
But,
On the 96 the fan configeration is slightly different using 3 relays. Both fans come on at same time in low speed mode with A/C or at 229*. And at high speed at 239*.
If youre only watching the needle yes it will almost be pegged when those fans are about to come on. Never understood where GM thought that was bright.
Can only imagine the line of LTx cars brand new lining up days after they were bought claiming they were overheating. Love to hear the service guys explain that one away. "Maaam its normal really"
Thank god for the star wars dash! Watching a red needle ride closer and closer to the peg would be way more stressful than watching the cooly lit digits flash higher by 1 degree every 2 seconds towards meltdown!
From: Supreme Soviet Peace-Loving Pipple's Kollektive of Seattle Wa
The problem really is the analog gage - its not linear so its hard to really determine the temperature. When the analog needle says 185 (major marker), the digital says 170 on my 96. Why GM decided to install such a cheap analog gage that is not linear is beyond me.
Put in a 165 stat and have your pcm programmed to have the fans come on earlier, had mine come on at 190 and off at 185..
Manual switch on my Dewitt's comes on @ 205. being a guy from way back when I hate to see anything above 220 so I can't wait for 229! It's just a psychological thing, the car it okay with it.
Put in a 160 stat and my digital gauge always says 142 my analog gauge says at idle 185 + or- some but as soon as you drive it it goes up to 260 but it isnt puking anything out and it runs fine and it goes up and down it is driving me nuts i have bled the system 3 times drained and refilled it. It is driving me crazy I am afraid to run acrossed town to pick my dog up at the vet!
you still have air in the system if it is acting like that
Next time you drain and refill try parking on an incline so the nose is up--it lessens the amount of air stuck in the steam pipe or heater core----you are running it on 90 degrees heater to circulate through the heater core aren't you?
I just got through pulling the radiator in my 86 because of over heating. I could not believe the trash between the radiator and the condenser. I used a high pressure hose on the radiator and condenser. You would not believe the dirt and junk that came out. After re-install and coolant it runs a lot cooler. I had been told its a good idea the do this every couple of years depending how much you drive.
The placement of the radiator combined with the low-hanging air intake is just a ****-poor design, corrected in subsequent generations -- or the C6 at least.
The analog temp gauge is as accurate as the last two bars of the fuel indicator....btw C4s are Really heavy to push 100 yards uphill to a gas station
I ran out of gas today because of that. BTW, they don't believe in gas cans here in Italy. My buddy brought me some spare fuel while a bunch of Caribinari (Police) asked me questions about the car. I don't speak much Italian, but it was okay. The scary part was it looked like they were suiting up for a raid. Have you ever had someone wearing a bomb suit ask you what size the motor was? It's almost a life changing experience. Anyways, the buddy brought the fuel in a bag. That's right, they have special BAGS OF GAS!!!
Anyways, I never liked that digital gauge. One of the projects on the list is to replace the gauge cluster with one from VetteAid. Yes, these cars run hot and they run hot very quickly. It's a pain to change the oil because by the time I get to the hobby shop, it's up there in temp.
