Door Panels
Old Sep 19, 2011 | 05:21 PM
LannyL81's Avatar
LannyL81
Default Door Panels
I did the "repair" to the door panels on my '95...added some sheet metal to the end three ribs.
I also replaced all of the door weatherstripping and have been fighting keeping the door panels in place ever since. Have not been able to see what it is that is keeping the door panel from staying in place. I have trimmed the new weatherstripping several times....but the panels will come off at the top if the door is shut hard.
Anyone have this problem after replacing the door weatherstripping?
I did the exact samething to my '96 and the panels are solid......
Old Sep 19, 2011 | 08:28 PM
whitenow's Avatar
whitenow
Default I used the 1" angles bolted to the top of the door
These hold the top of the door in place even with my new weatherstripping.
Old Sep 19, 2011 | 08:44 PM
adenloe44's Avatar
adenloe44
Cruising
Default Door Panels Issue with C4 vette
Why can't those that have made repair (s) to their door panels post picture of said repairs or fix? A picture is worth a thousand words..
Old Sep 19, 2011 | 10:32 PM
HlhnEast's Avatar
HlhnEast
I am not exactly sure what you are saying but I fixed one side laying fiberglass into the curve at the top along with about a 1" strip all along the top. The glass doesnt stick well but I backed it up with rivets when I reinstalled the weatherstrip. This is still holding well. The other side I just had a too thin metal strip running the whole length and it isnt doing well. you just need to increase the width of the part that clips over the door. There are a lot of different methods.
Old Sep 19, 2011 | 10:42 PM
Mustang_Eater's Avatar
Mustang_Eater
Yes, pictures please!!!!
Old Sep 20, 2011 | 11:16 AM
T-Factor's Avatar
T-Factor
I agree about pictures. I'm not sure I understand how the 1" by 1" angles are supposed to be mounted and bent.
Old Sep 21, 2011 | 03:51 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Old Sep 21, 2011 | 09:20 PM
pianoguy's Avatar
pianoguy
Here's a thread about the L brackets - I did this last year on my driver-side door on my '96, worked great:
http://www.corvette-guru.com/modules...orumpost128892
Note the comments in the thread about adding a little tape to the bracket to keep it from chafing the inside of the panel.
Old Sep 21, 2011 | 11:41 PM
adenloe44's Avatar
adenloe44
Cruising
Default door panel repairs
1st, thanks to all who have commented to-date on the need for photos on our repairs however small, easy, piece of cake (fill in the blank) they may be.. A sincere thanks to Pianoguy for locating a past panel thread with photos.. I would like to see other (s) who may have delt with this problem differently. Thanks also to Corvette Forum for keeping me in the loop when someone reply's.. This is what its all about, and what make the Forum work!! Anthony
Old Sep 22, 2011 | 10:19 AM
T-Factor's Avatar
T-Factor
Thanks Pianoguy for posting the thread with pics it was very helpful.
Old Sep 22, 2011 | 12:32 PM
pianoguy's Avatar
pianoguy
No problem - the thanks should go to corvetteronw for taking the time to provide the pics when he did his project, as he so often does.
To Door Panels
