automatic shifting
Old Sep 21, 2011 | 04:18 PM
FGVette's Avatar
FGVette
Default automatic shifting
I'm new to C4s. Newer Corvettes with automatic transmissions can control their shifting characteristics by computer programming. Is this the case with a 1986 automatic transmission?
Old Sep 21, 2011 | 04:36 PM
3D87C4's Avatar
3D87C4
No, the '86 uses the 700r4 & is not electrically controlled. I just browsed the stickies to see if I could find the year the 4l60e was introduced but failed---a search would probably find it, give it a try.
Old Sep 21, 2011 | 04:39 PM
RichS's Avatar
RichS
1994 was the first year for the electronic trans I belive.
Old Sep 21, 2011 | 04:44 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
93's could have either one, that's the year they started to put them in.
Old Sep 21, 2011 | 04:49 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
my 85 shifts way sooner with the original prom installed. The updated prom I bought in the 90's shifts later.
Old Sep 21, 2011 | 07:26 PM
Muffin's Avatar
Muffin
85 PROM has no control over shifts. TC lockup...yes but not shifts.
Old Sep 21, 2011 | 07:33 PM
Frizlefrak's Avatar
Frizlefrak
Correct. The TV cable controls shift points on a 700R4. And it isn't adjustable....it's either set correctly, or it's not. You'll know when it's not set correctly, because your transmission will burn itself up in short order.
Old Sep 21, 2011 | 07:50 PM
c4speed's Avatar
c4speed
From: Atco Raceway in between Pa & Nj 13.073 @ 106 MPH
Why ? Are you going on the 30th to run with us Fallon ?
Old Sep 22, 2011 | 05:52 PM
Cruisinfanatic
then why does it shift under lower rpm when using the original prom?
Old Sep 22, 2011 | 06:04 PM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
Old Sep 22, 2011 | 06:57 PM
Vette Jockey's Avatar
Vette Jockey
Roadster Madness. 😠
St. Jude Donor '13, '20-'21
To automatic shifting
