Please advice easy question
Old Sep 25, 2011 | 09:18 AM
hitmanpty's Avatar
hitmanpty
Default Please advice easy question
I need someone to tell me. where on the distributor cap. on my 1986 vette .spark plug wire number (1) go
I been having some problems with the ignition. and I see a couple of diagrams but not really sure where number 1 wire go on the cap.
I suspect, my are not in the correct place. please advice.
............................look like it was not easy question after all..................
Old Sep 25, 2011 | 09:23 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
#1 wire can go wherever on the cap, it just depends on where #1 TDC was when the wires were installed..
Your best bet would be to find TDC #1 and rewire it.
Here is where #1 is when the factory wired it.
http://members.shaw.ca/agent86/Spark...g%20Wiring.pdf
Old Sep 25, 2011 | 09:30 AM
hitmanpty's Avatar
hitmanpty
Thank you for picture. but not sure yet. Give me a couple of minutes and I will try to post pics of my cap. and pics of another cap I see here on the forum.. not sure how to do the TDC thing.
Old Sep 25, 2011 | 09:43 AM
hitmanpty's Avatar
hitmanpty
sorry i can show my cap pics I have them on my phone for some reazon is not working right now.
any way here is a pic of a distributor cap I copy from this forum. is clearly mark where the number one wire is.
in my cap I have number (8) wire on that position. and from there follow the fireing order. 8,1,2,7,5,6,3,4
[IMG][/IMG]
Old Sep 25, 2011 | 09:52 AM
navy_vette's Avatar
navy_vette
First thing to do to make sure your spark is set up correctly, TDC is the place to start. Pull out the #1 plug and have a buddy sit there with his finger in the hole (or just a wad of something. Make sure it doesn't go in!). rotate the engine manually until there is pressure. Once there is pressure, rotate the motor until the balancer mark lines up with the guide plate at 6*. pop off the distro cap and make sure that the rotating assembly is pointing at your #1 contact point.
Old Sep 25, 2011 | 10:25 AM
joe paco's Avatar
joe paco
[QUOTE=hitmanpty;1578791998]sorry i can show my cap pics I have them on my phone for some reazon is not working right now.
the order is correct, assuming you are reading it counter clockwise, CCW. if reading CW there is no way the engine could run.
Have you or someone changed the wire positions? because the picture that was posted of your engine recently showed the order correct, at least for 1, 2, possibly 8 and 3.
apparently the dist was installed out of position and wires were moved to compensate, which is not a fuctional problem. reinstalling the distributor may best be left to someone who has the experience.
Old Sep 25, 2011 | 10:34 AM
hitmanpty's Avatar
hitmanpty
let me see if Iget this right . once I get preasure on plug hole 1 by rotating the engine.that meat that I reach TDC on number 1.
then rotated engine a little more to get to 6* BTDC.
what this will tell meon relation with the distributor cap?????
Old Sep 25, 2011 | 10:53 AM
mike100's Avatar
mike100
The picture you have is correct position and firing order (18436572).
The distributor can only engage the oil pump drive two ways when the #1 TDC mark is at the 0-mark on the balancer tab. It will point to number 1 or number 6 post on the distributor.
If it runs, the tdc was for the correct cylinder. If you didn't know, the cam rotates half the speed as the crank so you have to rotate the crank twice to get 360 deg rotation on the distributor. The other tdc is for #6 cylinder. You just have to watch the valves to determine which cylinder is on compression stroke (#1 or #6).
Yours is right, you only need to adjust timing properly. There is a procedure to disconnect one wire to disable the computer advance so you can set the base timing. It is different for certain years, but you don't need any more than 10 degrees initial.
Old Sep 25, 2011 | 11:00 AM
hitmanpty's Avatar
hitmanpty
thank you for the information. something I want to point out. the picture is not my car. I finally fix my phone so give me a couple of minutes and I will post pic of my cap
Old Sep 25, 2011 | 11:06 AM
navy_vette's Avatar
navy_vette
At that point the contact on the rotating assembly inside will be touching the contact post for cylinder #1. You have to take the top off the distro to see and confirm it. If it's not, then you have to pull and readjust it or move the cables. I suggest taking the top off and getting the distributor sitting as it is supposed to.
Old Sep 25, 2011 | 11:10 AM
hitmanpty's Avatar
hitmanpty
this is my engine. if you compare to the original photo on top. number 1 position have number 8 cilinder in my.
my car is not start at this time.
I all ready change spark plugs and wires.this is an old photo.. but I use the same patern to conect the new wireing.
[IMG][/IMG]
Old Sep 25, 2011 | 11:11 AM
hitmanpty's Avatar
hitmanpty
[IMG][/IMG]
my engine look a lot better now. remember this is and old photo. taking the day I first got the car
Old Sep 25, 2011 | 11:23 AM
George6488's Avatar
George6488
May I make two suggestions that will save you a lot of time and frustration.
1. Locate and purchase the factory service manual for your vehicle. eBay will be a good source. Once you get the FSM...you will wonder why that wasn't your first purchase.
2. Find yourself a good mechanic that can help you get the car set-up and running. Once the vehicle is running then you can take over and get many things done yourself using the FSM.
I am a new Vette owner and the FSM was my first purchase.
Again.....just a few suggestions.
Old Sep 25, 2011 | 11:37 AM
hitmanpty's Avatar
hitmanpty
That sound very good Idea.I will get a manual. asap. but just by looking at the 2 picture. I can tell my wireing is all wrong. to bad the car is on my mother house. and today is my wife birday. for some reason she dont want me to go work on the car today. I think she is bigining to hate my car. since every free time I got I spended with the car and not with her.
Old Sep 25, 2011 | 12:04 PM
hitmanpty's Avatar
hitmanpty
look like it was no easy question after all.....
Old Sep 25, 2011 | 12:13 PM
hitmanpty's Avatar
hitmanpty
Default my spark plug
here is my spark plug. they all look the same lot of carbon. do you think this has something to do with the wire problem
[IMG][/IMG]
Old Sep 25, 2011 | 12:34 PM
cv67's Avatar
cv67
St. Jude Donor '05
Looks like an awful long plug>?!
No 1 wire is typically where the no 8 is. (your #2 wire would go where #1 is now) then move the rest over 1 accordingly. If it doesnt start then find TDC then see where your rotor is pointing. Should be towards the #1 cylinder
To Please advice easy question
Old Sep 25, 2011 | 01:11 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
If I recall, 1986 engines had iron heads early in the year & aluminum later. You have iron heads because the valve covers are perimeter bolt design not centerbolt. Either way, those long threaded plugs are not correct. Be sure you have the right plugs before going any further.
Old Sep 25, 2011 | 01:35 PM
cv67's Avatar
cv67
St. Jude Donor '05
Could be half his problem right there, almost looks like an LT5 plug.
Being as his location no telling what application that is really for.
Old Sep 25, 2011 | 01:40 PM
stoydido's Avatar
stoydido
[IMG][/IMG]
as if this thread is not complex enuff, this pic is not per the FSM, either. somone moved the wires CCW one position. #1 is normally where #8 is on this pic. doesn't matter since wires are marked. but it might matter if someone tried to duplicate it.
