o/d electrical problem
Old Sep 30, 2011 | 12:45 PM
justin_heat05's Avatar
justin_heat05
Default o/d electrical problem
1987 corvette 4+3 trans standard
I ran a 12v switch to my o/d plug-in and now overdrive works. So there must be an electrical problem.
Where should i start first? I already checked the switch on the gear shift, everything is fine with it. I read something about a relay may be the problem.
Where is the relay located?
This car has been wired on and worked on before. If i can't find the problem, is it okay if I bypass it with a 12v switch that is fused and run off of a hot wire that loses fire when the car is turned off? Has anyone done this?
Old Sep 30, 2011 | 01:47 PM
navy_vette's Avatar
navy_vette
It's either the switch or the relay. Are there codes for this? Does anything test the OD relay?
Anyways...
I don't know how you would test the switch, but...
Here it is.
If someone knows if you can T/S this, I would do it before you purchase anything.
Old Sep 30, 2011 | 08:30 PM
rodj's Avatar
rodj
Switch doesn't operate the O/d .It only sends a signal to the ECM to do so.
If everything in place and working O/d will operate automatically with out driver input.
Old Sep 30, 2011 | 08:32 PM
rodj's Avatar
rodj
Originally Posted by justin_heat05
If i can't find the problem, is it okay if I bypass it with a 12v switch that is fused Has anyone done this?
Also you have a 1st gear lockout switch at the trans that is part of the O/d circuit.
Old Oct 1, 2011 | 08:28 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Test your gauges fuse, if you haven't done so already.
Some help from my 86 FSM
http://members.shaw.ca/agent86/Overdrive-manual.pdf
Old Oct 1, 2011 | 10:06 PM
justin_heat05
thanks for all the help guys
To o/d electrical problem
