need help please
Old Oct 11, 2011 | 04:12 AM
jwolves's Avatar
jwolves
Cruising
Default need help please
ok this is the problem i'm having i have an 89 vette when i start it up in the morning it runs great it idle fine when you give it gas it wants to shut down feels like it is starving for fuel then when you let off the gas it will turn off and will not start until you shoot gas or starting fluid in the intake and then it will run very rough for about 1 minute and shut off this is what i have replaced so far the ecm fuel pump fuel filter fuel pressure regulator plugs wires cap rotor ignition mod egr valve it is not bringing up any codes next on my list would be injector it is the only thing i have not replaced do you guys think this is what it might be
Old Oct 11, 2011 | 05:02 AM
toptechx6's Avatar
toptechx6
Next on your list should be a factory service manual for your 89 if you don't already own one.
If you do, then I suggest following the step by step diagnostic chart for the symptoms you describe to isolate the problem.
You should have learned by now that the random parts replacement theory of auto repair is expensive and ineffective.
Old Oct 11, 2011 | 09:56 AM
Muffin's Avatar
Muffin
What x6 said. I suspect you have already wasted more $ throwing parts than the cost of an FSM. Have you at least, put an ohm meter on the injectors?
Old Oct 11, 2011 | 10:15 AM
Frizlefrak's Avatar
Frizlefrak
Look....no offense, but that gave me a migraine. Punctuation, please.
You need to start by testing your fuel pressure. Attach a fuel injection test gauge to the schrader valve on the fuel rail (looks like a tire valve). Turn the key on but don't crank the car. Yes, I know you've already thrown parts at it....now it's time to troubleshoot.
Tell me what the gauge reads. We'll go from there. This should be an easy fix.
Old Oct 11, 2011 | 01:01 PM
hitmanpty's Avatar
hitmanpty
now that you mention this. what is the normal preasure reading. I like to test my fuel preasure this weekend.
because in order to my car to start. I have to open the air to the max. after that I will have to play with the gas pedal into it stady it self in about 5 minutes.
Old Oct 11, 2011 | 11:26 PM
jwolves's Avatar
jwolves
Cruising
plugs/wires /cap/ rotor/ and mod needed to be replaced. the egr was not working. the old fuel pump pressure was only at 12 psi. with the new fuel pump and pressure reg the fuel pressure is with the key on engine off is 47psi. with the engine on it is 44psi. the test on the injectors. number 1 and number 7 are at 8.7 . numbers 2,3,4,5,6 and 8 are at 16.5 so it would seem that i need some injectors . but will 2 injectors cause it not to start . i can see it running rough but for it not to start at all?
Old Oct 12, 2011 | 06:58 PM
jwolves's Avatar
jwolves
Cruising
so what do you guys think
Old Oct 13, 2011 | 09:17 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
If #1 & #7 are reading low ohms they are basically shutting down that bank of injectors and your engine won't run.
Contact Jon@ficinjectors.com for free advice.
Old Oct 14, 2011 | 05:08 AM
liuhisn's Avatar
liuhisn
Try cleaning or replacing the IAC valve on the throttle body.
Old Oct 14, 2011 | 05:30 AM
FICINJECTORS's Avatar
FICINJECTORS
Supporting Vendor
1 bad injector will shut down the ecu. You need injectors! Call us
Old Oct 14, 2011 | 10:04 AM
oldalaskaman's Avatar
oldalaskaman
I vote this one
Old Oct 14, 2011 | 04:06 PM
corvettej's Avatar
corvettej
St. Jude Donor '13 thru '24
I had almost the same problem with mine, two injectors not reading 16.5 ohms, start but would not run long, replaced all injectors with bosch injectors. Car has been fine since, try unplugging the two bad injectors and start her, she should run but poorly I think I read that in my shop manual just in case you breakdown on the side of road or something. Good luck
Old Oct 14, 2011 | 05:22 PM
RLG's Avatar
RLG
You can't go wrong here. I replaced my stock injectors with Jon's injectors and it fixed my problem.
To need help please
