Stalling
Old Oct 14, 2011 | 05:16 PM
liuhisn's Avatar
liuhisn
Default Stalling
Hello to all. I have an '88 vette c4. The problem I am having is that it will stall when I take my foot off the gas pedal, otherwise it will run. I have cleaned the IAC modual and the problem still persist. I am leaning towards the timing and idling being out of sync. what are the steps to adjust this with a timing light?
Old Oct 15, 2011 | 08:35 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Are you 100% sure the IAC is working ?
Did you make any adjustments to minimum idle screw without re-setting TPS idle voltage ?
