hvac issue
Old Oct 30, 2011 | 11:54 PM
red89c4's Avatar
red89c4
Default hvac issue
89 with climate control is stuck on heat mode. i have had the controller (head unit) rebuilt. i have replaced the air mix door motor. worked one time and is locked on heat mode again. the air flow will change to selected vents but will not cool when dialed to 65 degree setting.
i am wandering if the air mix door could be binding and causing the cotroller and or air mix door to bur out? any help out there?
Old Oct 31, 2011 | 03:26 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Disconnect the rod from motor and push and pull it. You should feel if it's binding, or if the clip from rod to door is broken, you should feel no resistance.
Old Nov 1, 2011 | 09:46 AM
red89c4's Avatar
red89c4
also does the 89 have a programmer on the firewall? i have seen several discussions about that going bad
Old Nov 1, 2011 | 09:50 AM
87Vetteowner's Avatar
87Vetteowner
On my 87, the programmer is where an emergency brake would be. Left hand side of the drivers side. Find the hood release, the programmer is basically down from that.
It is about 4 inches or so square. It has a bunch of hoses coming out of it.
Good luck.
Old Nov 1, 2011 | 03:26 PM
Siveck's Avatar
Siveck
Programmer is on the firewall above the gas pedal. Note the vacuum line colors as the colors don't always match for reinstallation.
Old Nov 2, 2011 | 12:15 AM
red89c4's Avatar
red89c4
thanks guys!!! i will get to work on this, this wkend
Old Nov 6, 2011 | 11:27 PM
red89c4's Avatar
red89c4
took the programmer out and sure enough it had 2 resistors that appeared to have burned. flash spots around them with the printed circuit board discolored. took it to a local t/v repair shop and he re soldered the connections, at no charge. i gave him 10 bucks for lunch. installed the programmer in the car and it works beautiful. thanks to all CF members that helped with this!!!!!
Old Nov 14, 2011 | 08:23 PM
mjsvet's Avatar
mjsvet
3rd Gear
First time to the forum. Thanks for the information. My 89's heater would burn you out when ever it wanted. The programmer had a cold solder on one of the resistors. I was able to fix it myself. It came out easy, I unpluged the vacuum lines from inside the unit. It all was easer than I thought it would be to fix.
Old Dec 4, 2011 | 10:12 PM
mjsvet's Avatar
mjsvet
3rd Gear
Default Not Fixed after all Can someone help..
Well I thought this was fixed, but it is not. It blows hot air untill you have to slow down or stop. Then it blows cold air. It acts like a vaccum isue? Can any one help
Old Dec 4, 2011 | 11:04 PM
red89c4's Avatar
red89c4
mjsvet,
what happened? you said it was working, did it work correctly after you repaired the cold solder resistors? Mine works great after i had the resistors re soldered. perhaps they came loose again? if not then i would go toward a bad or sticking air blend door actuator. I paid $125 for one that i dont need. i would be happy to sell and send it to you. before you buy get an opinion other than mine as i am only guessing.
Old Dec 5, 2011 | 06:57 AM
mjsvet's Avatar
mjsvet
3rd Gear
Default Thanks
Well I thought it was fixed. It did have a cold weld. I am going to check out the programer again. If that's not it I will check out the other.
To hvac issue
