door lock release button
Old Nov 1, 2011 | 12:06 PM
Cavi's Avatar
Cavi
Default door lock release button
what is the correct name for the lock button on the inside of the door, the one you slide to open and close the doors? I am missing one and want to replace it but cannot seem to find it?
On that same note, my car, when I bought it only came with a single set of keys. Did most of the C4 (1994) come with automatic locks and a remote? How would I know if mine did and I was only missing the remote?
Old Nov 1, 2011 | 12:13 PM
Goldcylon's Avatar
Goldcylon
All MY 93 and up C4 Corvettes came with (Passive Keyless Entry) PKE standard. With two sets of keys and two remotes when purchased new.
Old Nov 1, 2011 | 12:14 PM
crzydrumer14's Avatar
crzydrumer14
should just be called 'Inside Door Lock **** Manual Slide' or something similar. I would just look on zip corvette, mamotorworks, or this website:
http://www.corvettesouth.com/corvett...6da215d17ceadf
And yeah as far as i know. almost if not all corvette cames with automatic locks and a remote. The trouble is, after 15+ years people have lost them, etc.. Your's most likely had one as did mine when it was born but its been lost over the years. I usually keep up with ebay looking for a good deal on one but the lowest ive seen one is around $150.
Old Nov 1, 2011 | 12:17 PM
Sweet 90's Avatar
Sweet 90
No remotes until around 1993
Old Nov 1, 2011 | 12:19 PM
Cavi's Avatar
Cavi
so I guess that is one more trinket to buy, then I take it it has to go to the dealer to program?
Old Nov 1, 2011 | 12:24 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
No, the programing procedure is in the owners manual.
Note: Be sure and research the C4 PKE system before spending too much money.
This system is unlike any other remote lock/unlock system out there. The remotes will be unique to the C4 and are not cheap.
Old Nov 1, 2011 | 12:25 PM
Goldcylon's Avatar
Goldcylon
Your Cars owners manual has the programming sequence. Also the Red two volume Factory Service Manuals. I suggest looking into purchasing one or the other.
The remotes come up for sale in the WTB/For Sale section all the time. On this forum. Also a lot of threads on the programming of the Fobs can be found here also on the fourm using the "Search" function.
Old Nov 1, 2011 | 12:26 PM
Cavi's Avatar
Cavi
the one on the link is for 84-98, will it still fit a 94?
Old Nov 1, 2011 | 01:59 PM
RollaMo-LT4
what link?
There is no such thing as a remote fob that will fit an 84-98
The C4 PKE system wasn't available until 1993 and ended with the 1996.
So, '84-'92 didn't have it. And '97-'98 are C5's and they are a different system.
You need to look for a specific FOB for the '93-'96 C4
Old Nov 1, 2011 | 02:10 PM
Cavi's Avatar
Cavi
http://api.viglink.com/api/click?for...13201710227031
this link for the manual door unlock button, it is only for the 84-89. I am having a tough time finding the correct one for the 1994
To door lock release button
