No VAT system
I have new pictures a new questios. here we go
this is the relay .there is 4 cables coming out of this.
1 green cable with white strips.
2 yellow cables
1 thin green cable
[IMG]
[/IMG]the 2 yellow cable coming out of the relay. come together. with 1 yellow cable coming out of the ignition swish
[IMG]
[/IMG]now in the other hand the push buttom have 2 cables. one go to the car battery direct. and the other go to the starter motor on passenger side on engine bay.
if I push the buttom the car crank no mattter what the ignition key position is
what can you make out of this
The small dark green wire is circuit 965. The VATS decoder grounds this wire to enable the start enable relay. If you grounded this the start enable relay would always be on when power was applied to the yellow wires. (One possible way to bypass VATS)
The green wire with white stripes is circuit 916. When the start enable relay is triggered power flows from the yellow wire, through the relay, through circuit 916 to the transmission position switch. (You have an automatic, right?) If the transmission in park or neutral the transmission position switch connects circuit 916 to circit 6 (the purple wire you asked about). Purple circuit 6 is supposed to go to the starter.
If the other end of purple circuit 6 is still connected to the starter then you could connect the taped off end to one of the yellow circuit 5 wires and, if your ignition switch still works, you would then crank when the ignition switch is in the start position. This bypasses the transmission position switch though.
If you want the transmission position switch to do it's job then you need to reconnect the purple wire to it. Make sure the green & white circuit 916 wire also still connects to the transmission position switch. Then you can bypass the start enable relay in one of two ways: ground the thin green wire (circuit 965), or connect the yellow wire (ckt 5) to the green & white wire (ckt 916) directly.
PS: Agent 86's scans are great, but they're black and white. The FSM schematic is in color which helps in identifying the wires. Your's is on order...right?
and reconect the purple cable to trasnmission position switch
also check that the green and with cable is conectect to the switch also.
if i get this right . if I ground the small green cable . that will make a bypass the VATs problem?
now the question is . where is the transmission position switch location
The transmission position switch should be in the center console associated with the shifter. It isn't shown in any of agent 86's scans however the "gear selector switch" in these figures
http://members.shaw.ca/agent86/Under...nter%20Console
http://members.shaw.ca/agent86/Underneath%20Console.gif
are labeled as the transmission position switch in my '87 FSM. Here are the corresponding figures from my FSM:
The best way to get them is to purchase a factory service manual for your model year.
http://www.helminc.com
Where I've posted pictures, they are scans from my FSM.
It measures the pellet resistor in the ignition key and disables the starter and fuel injection if the wrong value is detected. This should be discussed in your owner's manual.
I want to tell very one how I did fix the cable push buttom start.
1-I began on the start enable relay. I follow the green wire with white stripes. I make sure it go from the relay to the trasmision position switch. that was ok
2-them I located the purple wire. make sure go from the TPS to the starter motor. that was ok.
after that all I have to do is connect the yellow wire to the green with white stripe wire.
at this time I imagine that I can make the conection on the relay it self.
so here are some pics of what I did.
I remove the relay. from the plug
[IMG]
[/IMG]I get a thin metalto use as a connector
[IMG]
[/IMG]
here isthe push buttomand old cable. ready to go to the trash
[IMG]
[/IMG]key start ok now.
thank you all again.
I still dont know what that purple wire is for. All I know is not coming out of the trasmission selection switch. it go back on the dash and lost in a world of colored cables.
here is a pic of that cable in case you dont remeber
[IMG]
[/IMG]
[/IMG]
