No VAT system
Old Nov 6, 2011 | 10:27 PM
  #41
hitmanpty's Avatar
hitmanpty
I think is in color. Takin in consideración the diagram of mr 3D87c4
Old Nov 7, 2011 | 12:17 PM
  #42
3D87C4's Avatar
3D87C4
Congratulations!
Your bridge between the yellow and green/white wires is...interesting, but should work as long as good contact is maintained. Just be sure it's well wrapped in electrical tape or otherwise insulated.
I was wondering about that purple wire, it really didn't belong in the dash if it was what I thought it was. Its good you traced all the wires before making any changes. You'll probably figure out what it is as you continue working on your car.
Keep at it, you're making a lot of progress.
Wayne
Old Nov 7, 2011 | 12:19 PM
  #43
3D87C4's Avatar
3D87C4
Originally Posted by Cavi
Will the shop manual have all the schematics in color or black and white?
The FSM for my '87 has color schematics. I don't know about other years'.
When you order yours be sure to order the electrical diagnostic supplement too---that's where most of the schematics are.
Old Nov 7, 2011 | 01:11 PM
  #44
Siveck's Avatar
Siveck
Good work with eliminating the push button .
Old Nov 7, 2011 | 02:52 PM
  #45
hitmanpty's Avatar
hitmanpty
Originally Posted by 3D87C4
Congratulations!
Wayne
I finish the job by tape all that plug with electrical 3M tape
Old Nov 21, 2011 | 09:21 AM
  #46
hitmanpty's Avatar
hitmanpty
Unable to start the engine
when servicing the starter relay. the car battery was almost dead. had only enough power for lights. but when I turned on the car, I could hear the starter clcik. but the engine would not turn.
I figured the problem was low battery. so I asume that the problem was solve, and all I need was a new battery
This battery I has was a 620 amp
went out to buy other batteries. the old one was giving me many problems all ready.
buy a 630 amp batterie
when installing the Batteries in the car. same thing happened. only could hear the starter click but the motor does not rotate.
the factory recommends a 700 amp batterie. I am going on lunch break to buy a 700 amp batterie. I hope this solve the problem
important to mention. is that before removing the cable with the power button. the car start with the 620 amp batteria. if it was fully charged. I did recharge that battery a couple of times . but the last time the car did not start, with the push botton still on the car and the 620 amp battery fully charge.
any suggestions before going to buy another bateira ??????
Old Nov 21, 2011 | 10:13 AM
  #47
hitmanpty's Avatar
hitmanpty
ttt
Old Nov 21, 2011 | 01:45 PM
  #48
hitmanpty's Avatar
hitmanpty
ttt
Old Nov 22, 2011 | 10:33 AM
  #49
Siveck's Avatar
Siveck
Temporarily attach the old push button harness if you still have it to verify that the battery and starter are still good. A weak battery or a bad starter/ solenoid will make it click.
Old Nov 22, 2011 | 11:46 AM
  #50
hitmanpty's Avatar
hitmanpty
before I disconnect the battery cable. it will give me the same problem at the end. even do I had full charge battery.
I open another thread about this. people are telling me is the starter solenoid.
Old Nov 30, 2011 | 02:03 AM
  #51
Cliff Harris's Avatar
Cliff Harris
I bought a FSM for my '86 when I first got it and all the diagrams were in color. Over the years it fell apart so I bought a new manual from H.E.L.M. about a year ago. They went cheap and all the diagrams are now in black and white.
Old Nov 30, 2011 | 10:41 AM
  #52
hitmanpty's Avatar
hitmanpty
I just bought a manual on pdf on ebay. I guest I will get it next week.
but is in black and with. what I will do is go to a print shop, and print it.
and save the CD as a back up
Old Nov 30, 2011 | 11:04 AM
  #53
pcolt94's Avatar
pcolt94
A bigger battery will not solve your problem. A 500 amp battery will start the engine just fine if the rest of the cars electronics are working. A bigger battery will just give you more cranking endurance (turn over longer) than a smaller battery will. A bigger battery will probably start the engine easier in very cold weather like 10* F or colder. Or might be needed for a very high compression engine.
If it is not cranking with a fully charged (any kind) of battery, the problem is with the starter or the voltage going to it. Like bad battery connection, cables etc.
The alternator supplies your current needs while driving the car.
Old Dec 1, 2011 | 08:44 AM
  #54
hitmanpty's Avatar
hitmanpty
i WILL DO A starter bench test this weekend
