Engine Cost Replacement
Old Nov 9, 2011 | 12:11 PM
RedLS1GTO's Avatar
RedLS1GTO
Originally Posted by RedLS1GTO
...replace with a good one ...
Originally Posted by Frizlefrak
Unless it's of Chinese descent....
You should know better than that.
It really depends on how bad/where the leak is. Why did it start leaking? Is it a material issue? Will a new leak happen as soon as you fix this one?
If it is a leak from an impact/rock/etc I would have no problem fixing it. You fix the hole and yo uare as good as new. If it is a "natural" leak, it really makes me wonder how many more are about to happen.
Old Nov 9, 2011 | 01:17 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
That seems high, 80k mile motor is kind of taking chances.
Rebuilding the stocker would be less. Even if it cost the same its worth it to make it like new.
Old Nov 9, 2011 | 02:44 PM
desertmike1's Avatar
desertmike1
robsball; If there is any way you can attempt to do this yourself, do it. You will thank everyone later on for talking you into this, it really is a fairly straight forward, and simple job.
Old Nov 9, 2011 | 03:23 PM
cv67's Avatar
cv67
St. Jude Donor '05
If you drove the motor with a leaky gasket for any length of time beware it can mess up the bearings. If your oil pressure was healthy then just do the head gasket.
Absolutely have the heads surfaced!! A quick mill wont change the compression any noticeable amount, even if they got aggressive it wont hurt the motor thats a wives tale. Gotta be nice and flat to seal.
That used 89 motor. Bet it hasnt had the gaskets done, those will fail too. They all did.
Old Nov 9, 2011 | 04:01 PM
80sRule's Avatar
80sRule
+1. Buying a used motor when you have a rebuildable one is just buying another set of crap to break.
If you really go spendy and do all the "while you're there" stuff, even paying someone else, you'll spend not as much as you think on a SBC. I did head gaskets on my 87 this year because it was spraying out on the exhaust manifold (never leaked into oil or cylinder, weird leak); I did a full Victor Reinz gasket set, new water pump, thermostat, all new hoses, heads resurfaced, valve grind, new guides and seals and fluids. I did this for under $500 and I used ACDelco for everything but the head gasket set; AND I know what's been done, unlike a mystery motor.
Even if you pay someone else, if they're honest, you'll spend less than the scenario you've outlined. I'd pay the tow and GTFO of his shop.
Old Nov 9, 2011 | 04:58 PM
kh400's Avatar
kh400
Originally Posted by robsball
A sad day for me, my baby is in the shop and is requiring a new engine.
Ok here it is, mechanic has a 80k replacement engine out of an 89 into my 89. Cost of engine is 1800. Labor 1500. Misc radiator replacement, hose and lines replacement an addition 500. Total cost 3500.
Too much? Or what. Any suggestions welcome because not fixing her isnt an option.
thanks
Robin
Have the shop quote you a price on a remanufactured long block. $1800 for an 80k mile engine seems steep. And if the engine is no good, you could lose your cost of labor. Something to think about. Good luck!!!!! Also, most definitely replace the radiator. They aren't that expensive and will cool much more efficiently than the old one. Cheap insurance.
Old Nov 9, 2011 | 05:51 PM
96GS#007's Avatar
96GS#007
New head gaskets: $40
New waterpump: $60
Flush radiator: $50...most of the work is done since they have to drain it to replace the gaskets
Other gaskets (intake, TPI, exhaust manifolds, etc): $100
Refresh the heads (clean, replace seals, resurface): $200
Misc parts, fluids (oil, coolant, water) and Labor for all: $900
Total: $1350
Since labor rates vary, you should end up between $1000 & $1500. Anything else is a ripoff.
Old Nov 10, 2011 | 01:13 PM
aklim's Avatar
aklim
So I can't help but thinking he saw a skirt and rubbed his hands greedily together.
Men don't always get excited by the skirt. It's what's inside that counts. Unlike the other guy, I will say
Why do you think that when the car needs work, I never allow the wife to do more than pick it up? She doesn't talk to the techs, no eye contact, just pick up the key and leave. I'll have taken care of it all. OTOH, when we go to the doctor, I just repeat what she said and nod my head. She makes all the decisions before we get there.
That said, where are you located? If you are not driving it, can you wait? IIRC, DeWitts is having a sale in Jan for radiators. Might as well have a good clean radiator.
Old Nov 10, 2011 | 02:48 PM
mtwoolford's Avatar
mtwoolford
how many miles on your original engine ? unless your original engine has a zillion miles on it, uses / burns oil, or suffered a massive overheating, a blown head gasket is rarely enough reason to replace the engine.
pull both heads, visually inspect for damage.
send heads to a reputable machine shop that does (a lot of) heads on a production basis
have heads inspected...mostly for cracks eminating from the exhaust seats and passages (the hot spots) if okay get a quote: grind valves and seats...inspect and replace valve guides as needed....new springs (maybe)....new seals (definetly)...and have the heads surfaced just enough to ensure that they are completely flat. This is just the basic garden variety vavle job and should not be that expensive. Ask them about their getting the head gasket set also...they will probably do it at a discount.
replace the heads onto the engine...call it a day.
sure...replace the water pump...bust a couple bucks and get a quality new pump...they aren't that expensive...and they are good insurance.
replacing the radiator ...thats something that can be done later, but do take the original into a radiator shop, have it back flushed and pressure tested...that should be enough at this point...of course replace it if it's marginal or the budget can afford it.
an ignition tune up and oil / filter change and you should be good to go for a long time.
p.s. for eighteen hundred dollars you should be able to do MUCH better than an used 80,000 mile engine...just go online and do a little "finger" shopping.
and don't let anyone blow smoke up your .....or as my wife was told by a national tire chain, "The reason your tire keeps going flat is that your husband puts too much air in it" (turns out a previous patch job done by them didn't seal completely).
good luck, keep us posted. It's hard enough keeping a C4 on the road, and I already don't like your shop. Don't let anyone convince you to throw your "baby" out with the bath water.
Old Nov 10, 2011 | 06:25 PM
cqlink's Avatar
cqlink
The shop is still on Rt 1. Can't remember name. It's on the right as you head north out of Fred. Plenty of Vettes out front.
Old Nov 10, 2011 | 06:27 PM
cqlink's Avatar
cqlink
If you pull and resurface heads be sure to use new head bolts as well.
Old Nov 11, 2011 | 05:41 PM
VistaVette's Avatar
VistaVette
I didn't read every post here but IMO I'd never replace the motor on my car; I'd have it rebuilt for a few reasons but two majors: First if its a car you're going to keep do it once and do it right. Second it would bother me that the original motor is gone.
Old Nov 12, 2011 | 10:14 AM
  #33
mtwoolford's Avatar
mtwoolford
Originally Posted by VistaVette
I didn't read every post here but IMO I'd never replace the motor on my car; it would bother me that the original motor is gone.
amen brother ; and, if past history is any indication, as c4 prices appreciate, that "matching number" engine will become VERY important
Old Nov 12, 2011 | 10:48 AM
  #34
anciano's Avatar
anciano
Thank you for brightening my day. Now if the Tooth Fairy comes by riding a unicorn and tells me where to find the leprechaun's pot of gold it will be a PERFECT day.
But, hey, it never hurts to dream. You big city folks down there in Folsom must be congenital optimists. Us hillbillies up here in Placerville have to face a harsher reality.
Old Nov 12, 2011 | 12:06 PM
  #35
Paul Workman's Avatar
Paul Workman
... Except for a cracked block or cracked heads, or a block that has been bored beyond .060, or one that has had a rod break and subsequently destroy the block, the original block can most likely be refurbished - but waaay to early to talk about that stuff till we see what the problem is first.
Machine shops are hungry. So, one has to be specific, to avoid some shops from being given an inch and taking a mile. I'm just sayin...it is easy to get taken for a ride. A tight leash is usually a good thing.
Because the gasket problem is common with this particular vintage SBC, I believe doing both gaskets now would be prudent. However, to flux the heads for cracks means disassembly and hot tanking, grinding, etc, etc. would be SOP for a rebuild.
But, in this case, it is still just a repair. Without reason to expand the project, I'd lean toward the KISS principle - for now, anyway.
Not to disagree with anything you said, but I often have to remind myself to draw the line somewhere before changing the thermostat becomes a complete overhaul..."while I'm at it!!"
My point is, replacing the head gaskets is a drop in the bucket, compared to the time and $$$ for a full R&R of the heads; so much so that unless there was reason, it makes more sense to fix the simple problem, and plan the R&R for a later day, if needed.
Not arguing - but knowing me, I often go way beyond the pale myself, and I suspect some of that in yer post. Its OK. As a hobby to me (and maybe you too) I don't always need a reason to tear something down at the slightest provocation. (I should have been a certified aircraft mechanic!)
P.
Old Nov 12, 2011 | 01:42 PM
  #36
Marv02's Avatar
Marv02
I must agree with KISS.
But if your going to get the heads done get both of them done at the same time find out what they want to charge you before they do the work.
Price a set of after market heads and see what the better deal before you go get the heads done.
Something like this but you need to call them I think this price is for a set.
http://www.summitracing.com/parts/TFS-30310005/
Old Nov 12, 2011 | 03:38 PM
  #37
24695bob's Avatar
24695bob
One of the best reasons (except the beer at the meetings) of belonging to a Local Corvette club is the availability of information ..like what shops to AVOID as well as what shops do good work at a reasonable price...
I do most of my own work..BUT I have one mechanic that I use for my C1 and C3's ( 40 some miles from my home) and another for my C4 and C5s who is located much closer in town..... and I "follow" one local guy who does alignments and go to the shop where he is "currently" working" same deal with electrical problems (I use one man just for those problems IF can't solve or myself...
BobG
To Engine Cost Replacement
Old Nov 12, 2011 | 04:32 PM
  #38
richauto's Avatar
richauto
Well I got edumacated about short/long block etc.
The initial issue was white smoke coming out of the exhaust, I shut her down and checked oil - was good.(Doesn't leak or burn - never have to add and I check it consistently)Then notice a big steady drip of coming off where the muffler attachs so drove it to the nearest muffler shop - there the mechanic thought it was a blown head gasket. Had it towed home.
Called some auto shops next day (DIY - not happening) and one of the shops came out and picked it up and took it to his shop and verified the blown head gasket.
To make a long story short, he quoted me the 3500 for the 80k 89 SHORT block and transfer of parts and assembly. When I realized what that meant I was like oh H*** NO.
Told him this morning, I wanted the head gasket replaced and didn't want it to go to a machine shop to have them rebuilt - that would change the dyanamics of the compression to the bottome part of the engine. He agreed and said they would pull it and check it for warp damage, and I was welcome to come in and see if they discovered some. Then I told him I wanted the radiator, thermostat and water pump replaced. He is working me up a price as I write this.
Knowledge is power!
If you are replacing the head gaskets it's good practice to have the heads cleaned,pressure tested and milled(IF NEEDED).Good luck
Old Nov 12, 2011 | 09:39 PM
  #39
George Dickel's Avatar
George Dickel
I agree. Overheating doesn't cause the gasket to leak, the heat warps the head which causes the leak. As a minum have the head checked for warpage otherwise it will leak when you re-install it even with a new gasket.
Old Nov 12, 2011 | 09:48 PM
  #40
George Dickel
$1,800 for a used engine with 80K is an absolute rip off. There is nothing special about an 89 Corvette L98 engine, it is no different than a 350 taken from a Chevrolet pick up truck. Perhaps the heads are a bit better but a small block 350 is a small block 350. Get your Vette out of that rip off joint and find a reputable mechanic. This place has tried to screw you right from the get go, why do you think they will treat you better since you just want the leaking head gasket repaired. Once they tear it down they have you by the short hairs, your car in pieces all over the shop and they tell you the engine is shot (probably a lie) but you will have to pay towing, labor for tearing into the engine and anything else they can find to charge you.
