FOB problems I think..... help
Old 11-14-2011, 08:31 PM
buddys redhaze
buddys redhaze's Avatar
Default FOB problems I think..... help
I have a 94 coupe my fob does not lock or unlock the doors but fob will unlock hatch. I can manually lock doors and fob will unlock passenger side door only. I need some advice thanks in advance.
Old 11-14-2011, 08:33 PM
GreyGhost
GreyGhost's Avatar
try holding down the door button on the fob until the locks cycle, it will first unlock the drivers door and then if you hold it longer, it will unlock the passenger side.
Old 11-14-2011, 08:52 PM
RollaMo-LT4
RollaMo-LT4's Avatar
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
I have to ask what you mean by "my fob does not lock or unlock the doors"?
The C4 PKE (Passive Keyless Entry) system is unlike any other FOB.
The door button on the FOB will never lock the doors, and as you have discovered will only unlock the passenger door.
Passive means, there is no action required on your part. As you walk away from the car, the doors will lock. As you walk back up to the car, the drivers door (or both doors depending on how you've set it) will unlock.
If that is not what is happening now, it's possible the system is turned off. In that case, do as GreyGhost mentioned and hold down the door button while standing next to the drivers door.
After a few seconds you should hear the locks cycle. If the system was off, it will now be on. If it was on, this will shut the system off.
The system is explained pretty well in the owners manual.
Old 11-14-2011, 09:28 PM
buddys redhaze
Thanks Gray Ghost tryed it and it worked. I've got a lot to learn about my 94.
Old 11-14-2011, 10:10 PM
GreyGhost
GreyGhost's Avatar
Old 11-15-2011, 09:56 AM
markKlein
markKlein's Avatar
Please read Rollas post carefully. The fob button still does not open the drivers door. It never will. The door is now unlocking because you have turned the PKE function "on". You can also set the car to unlock both drivers and pass. doors passively. The fob button will never lock the doors, only walking away will.
Old 11-15-2011, 10:41 AM
buddys redhaze
Thanks Mark I understand. All help is greatly appreciated.
Old 11-15-2011, 12:38 PM
markKlein
markKlein's Avatar
No problem, I guess I misunderstood your reply. Good Driving!
To FOB problems I think..... help
Quick Reply: FOB problems I think..... help
