hood support question
Old Nov 21, 2011 | 10:12 AM
hitmanpty's Avatar
hitmanpty
Default hood support question
I just get my self from ebay an used hood support for my 86 vette. it cost me about $40 with shipping includ
It had a fix a aftermarket screw in the center.
After I install the part I have to guide it with my hand to fit in position since is wave fron site to side. Is this normal?????
here is a pic of the part all reay instal
[IMG][/IMG]
Old Nov 21, 2011 | 12:24 PM
Y-ME's Avatar
Y-ME
Nope should not be like that.
Old Nov 21, 2011 | 01:23 PM
hitmanpty's Avatar
hitmanpty
i KNOW IT HAVE AFTERMARKET SCREW on Iam talking about wave move from right to left
Old Nov 21, 2011 | 04:58 PM
c4speed's Avatar
c4speed
From: Atco Raceway in between Pa & Nj 13.073 @ 106 MPH
Get an old broom handle cut to lenght and carry it in the back return the part, works just as good.
Old Nov 21, 2011 | 05:12 PM
dukeallen's Avatar
dukeallen
and it's good for self defense too.
Old Nov 21, 2011 | 06:03 PM
popo8's Avatar
popo8
Does not look normal to me....
Now off topic, and I appologize in advance.... what cold air set up are you using.... it appears the filter is on the back side of the radiator, rather than over the rad support.
Old Nov 21, 2011 | 06:05 PM
nutz4c4's Avatar
nutz4c4
Ya wasted $40.....
Old Nov 22, 2011 | 01:04 AM
Cliff Harris's Avatar
Cliff Harris
I got one of the later year tube supports that goes on the DRIVER's side, where a hood support belongs. All the holes were already there and I used the bolts from the scissors style support, which went in the trash. Now I don't have to walk around the car to close the hood.
Old Nov 22, 2011 | 02:45 AM
gerardvg's Avatar
gerardvg
Hi
You will get a bit of sideways movement in the hood support.
This is mainly due to it being fixed to the plastic wheel well parts,
I put a 1/16 plate there to support it to various fixing points and it barely moves now. I did remove the support a while back and hammered the rivet a bit to take out the play.
I do like how the designers put the hood support on the right side, must have been for r/h drive..... kind of nice.
I don't have to walk around the vette to close the hood
in my right hand drive vette
Old Nov 22, 2011 | 08:48 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Look for late 86-87 push button strut and brackets or the gas charged 88+ strut and brackets.
Those scissors give me the *******
I opted for the gas strut setup using my existing lower bracket. I still have the push button strut that you could have for the cost of shipping, but you would still need to find the lower bracket.
Old Nov 22, 2011 | 09:27 AM
CREWZIN's Avatar
CREWZIN
I upgraded from the 87 push-button to the 88 gas charged strut. One of the best things I've done.
Old Nov 22, 2011 | 10:01 AM
Daniel_Mc's Avatar
Daniel_Mc
I just use a metal dowel and have a rubber vacuum line cap on each end to keep it from slipping. When not in use it lodges right where the doors for the rear storage compartments are so it does not roll around.
Sorry this is the only picture I have of it. You can see how it fits at the base where the stock hood support went. Maybe you could do something similar to help steady the hood on your Vette? This would be the cheaper fix. However I would consider taking AGENT 86's recommendation to install the 88+ style set up and be done with it.
Daniel
Old Nov 22, 2011 | 05:30 PM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Carey, Did you ever see the article I wrote on this and upgrading the rest of the hood hardware to late C4 back in '94 called HOOD HOSPITAL?
Hope you are keeping well.
Old Nov 22, 2011 | 07:45 PM
CREWZIN's Avatar
CREWZIN
Ray,
Doing OK. No, sorry must have missed that write-up.
I also updated the small struts at the front of the hood at the same time I went to the gas strut. Believe it or not, it was too good. When I lifted the hood (which only took 2 fingers compared to both hands I had to use before) all 3 new struts took over and slammed the hood open against the hood stops. I'm sure it would eventually break something if I left it that way, so I put the old small struts back on except for the large gas strut. Works real nice and easy now.
Old Nov 23, 2011 | 06:20 AM
Ray Quayle's Avatar
Ray Quayle
Cruise-In I Veteran
Ray,
This was covered in my article. When they went to the gas charged support, they did away with the passenger side assist strut and only used one. Next time you get a chance to see an original late C4, take a look at the hinge area and you'll see only one assist strut. The mount is there for the other, but only one was fitted and you discovered why.
To hood support question
