Is there a way to check for pulse voltage from the ecu TO the injectors? Can I stab the inj. wires with a 12v continuity light to BE SURE the problem lays with the ecu and NOT the injectors? My 1989 has had new injectors installed about 2k ago,allong with a new fuel/air filter/egr/plugs/cap/rotor/wires. Overnight, it now just cranks but will not fire. A shot of ether will let it run for seconds. Sometimes while cranking the stater motor will just stop. HAd it & the battery checked out, both good. H E L P !!
Look up 'noid light' and you'll have your answer. You can't just plug in a DVM and get a result. There is an ohm reading for resistance of the coils, but as far as injector pulse, you'll need a 'noid light'. You can get a test set from Harbor Freight.
Finally, if you're doing the kind of things you're doing to your Vette', by all means, you should have a FSM or Factory Service Manual. You should also be looking at what, if any codes are thrown by the ECM. Go to the C4 tech forum and do a search on the problems on your 89'. Early C4's are notorious for starting, ignition and fuel problems. They are complex and you have to go step-by-step in figuring it out.
Are you sure there's fuel pressure? Maybe the problem is fuel pressure related. Pump, regulator and filter condition?
Yes, I have 40psi at the rail. A few days ago it actually DID start but wouldn't STAY running unless I brought the r's up to 2.5k. Let it run 'till the fans kicked on, then shut it off. It started immediatly again and idled normal. Yesterday & today....once again, it will not fire up unless primed with ether.
I WAS lucky enough to pick-up a FSM & Haynes on e-bay & it arrived yesterday Would the TEMP sender in front of the motor have a effect on what the ecu tells the injectors? On another note, is there an EASIER way to get at the ecu other than inverting ones self in the passenger seat and try to axcess the mounting bolts to it? The "bread-box" is next to impossible to get out of the way unless the ENTIRE dash pad is removed. No wonder they moved it into the engine compartment for the following years!
The ECU is almost always the last thing that goes bad. What inputs it recieves from the various sensors is far more likely. Have you seen what codes it's thrown yet? Are you familiar with how to retrieve the codes from your car? It's pretty easy. You just jump the connector under the dash with a paperclip. One end goes to "A", the other to "G" and then you turn the ignition to run (don't start the car). You should get an immediate 'flashing' of the SES or Service Engine Soon light. The first three sets of flashes are the "Hello", then it will start to flash the codes three times each. Three flashes an interval and then Six flashes is Code 36. This will repeat two more times and then it will go on to the next 'set' (it's been awhile, so anybody, feel free to jump in to correct me!
THAT'S the problem...all I'm getting is the 12 code showing the computer is working....NO other trouble codes AT ALL!
There's a section in the FSM that has a "No Codes" troubleshooting procedure. You'll need to go in there and check out each function and sensor as it's called out, one by one.
When I needed to check that I went super simple and just plugged a light bulb in the injector socket. A spare from the digi dash worked very well.
The computer is really easy to get down, I thought. Remove the hush panel, use a mirror to look up while sitting along side the car. Then with a long extension undo the two 10mm bolts. The computer drops down.
I had a reoccurring bad o2 code once. Replacing the sensor did not help. I followed the FSM chart and found the circuit good. Then followed the chart for bad ECU. I did not get the bad ECU code but that was indeed what the problem was. Replaced the ECU and it was fixed. I made a thread on it awhile back.
