Erod ls3
Old Feb 22, 2012 | 01:23 PM
  #81
Cavi's Avatar
Cavi
Good attitude, I personally would go nuts!!!
Old Feb 22, 2012 | 01:30 PM
  #82
C4orce2's Avatar
C4orce2
Originally Posted by 3D87C4
In fairness, I probably shouldn't have passed along that original ETA, we were all pretty fired up. It's a busy shop & a project like this has to be scheduled around other customer needs. The electrical and fuel system work they've been doing is important, but doesn't yield a lot of photo's for me to pass along. My feedback is "take the time you need" & I mean it. We're in contact once or twice a week & I'm happy as long as things are progressing.
Most of the time while my LS376/480 Hot Cam was being installed I was working in Europe. I took one issue of "Vette" along with me and found an article about how to pick a company to do restoration/modification work on your vette. Their advice was that no matter how much homework you and your choosen shop have done, there are two rules that always seem to be true: it will take twice as long as estimated; and it will cost 50% more than estimated. In my case, both rules turned out to be right on. You never know what type of problems the shops run into during these builds and surprises are to be expected.
Old Feb 22, 2012 | 01:35 PM
  #83
C4orce2's Avatar
C4orce2
Here's the new bracket and mounted pedal:
I'm gonna have to wash that brake pedal, I guess.
When you get your car back, be very careful at first with the new location of your gas pedal. When my "drive by wire" pedal was installed it ended up almost flush with the brake pedal and very close. You have to be careful that you are not applying the brake when you are on the gas. Just a heads up!
Old Feb 22, 2012 | 01:49 PM
  #84
3D87C4's Avatar
3D87C4
I did that twice when I was a kid driving mom's '64 Buick Lesabre. Had my foot on the brake and gas, in gear, & that big 400+ci engine was roaring and bucking while I worked out how to slide my foot off the gas without releasing the break! I've been pretty careful about my right foot placement ever since.
Old Feb 22, 2012 | 01:55 PM
  #85
3D87C4's Avatar
3D87C4
I miss my vette as much as the next guy, but this would probably take years if I was doing it, so I'm cool.
The thing that get's me is the weather. This was supposed to be happening while the winter weather kept the vette in the driveway & instead we have a drought. My luck, it'll pour when the vette comes home.
Old Mar 5, 2012 | 03:34 PM
  #86
chvz99's Avatar
chvz99
6th Gear
nice setup . hey if you dont mind could you give me the part number for the pcm , i ve been looking all over and cant find it. i want to run it with my setub, lsx376. i got all the part numbers needed exept the ecm . thanks
Old Mar 5, 2012 | 03:44 PM
  #87
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Old Mar 5, 2012 | 08:52 PM
  #88
3D87C4's Avatar
3D87C4
Here's what it says in the CA executive order (D-126-30):
I got a call Friday saying great progress had been made mounting the ECM, fuse box, TCU and cruise control module & will pass along pics as they arrive. I passed along the ECM part number question too.
Old Mar 6, 2012 | 11:47 AM
  #89
3D87C4's Avatar
3D87C4
Here you go:
Old Mar 6, 2012 | 03:18 PM
  #90
C4orce2's Avatar
C4orce2
Just a heads up to you guys putting in the Erods. The kit that I bought to go with my LS376/480 Hot Cam included a E67 computer (the same computer that is used on the CTSVs). When it came time to have it tuned, one shop kept trying to tune it with the EFI Live program. After trying it time and time again, they gave up. It was finally tuned using the HP Tuner program. Not sure if that is the same computer that you will be using with the Erods, but if it is, you should give this heads up to your tuners.
Old Mar 6, 2012 | 04:07 PM
  #91
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
Awesome thread!
Old Mar 6, 2012 | 05:11 PM
  #92
3D87C4's Avatar
3D87C4
I know nothing about tuning, but the EROD installation instructions include this:
I've been assuming this was the needed "factory tune".
Old Mar 6, 2012 | 05:47 PM
  #93
C4orce2's Avatar
C4orce2
I'm certainly no expert, but I do not believe this has anything to do with tuning the computer. With my E67 I had a few drivability issues. My tuner told me that most new computers are tuned for 93 octane gas. In AZ all we can get is 91 so the first thing he did was make the adjustments for the type of fuel I can get. He actually backed some of the timing out. This actually made the engine run better. He then used his loaded dyno and tuned the car at various speeds right on the dyno. As a result he improved the drivability issues and increased the hp and tq at the same time. My final tune showed rwhp of 429 and rwtq of 442 on his loaded dyno which usually gives lower numbers than a dynojet. I doubt that anything you get from GM will have to do with tuning the car since they send it to you pre-tuned to their specifications. Of course I could be entirely wrong but this is what I was told.
Old Mar 6, 2012 | 06:02 PM
  #94
3D87C4's Avatar
3D87C4
Ok, thanks, looks like another thing I need to read up on.
Old Mar 6, 2012 | 06:56 PM
  #95
chvz99's Avatar
chvz99
6th Gear
thanks for the foto , the guy im talking to is trying to see if he can get me the same tuning on that computer , because i went to gm and they sell all their ecms with out any programing
Old Mar 13, 2012 | 12:44 PM
  #96
3D87C4's Avatar
3D87C4
This week's update:
ECM, fuse box, TCU and cruise control module have all been mounted.
Next step, powder coat the motor mounts & install the engine!!!!
It's starting to rain here so this project must be just about done.
Old Mar 16, 2012 | 07:00 PM
  #97
3D87C4's Avatar
3D87C4
Got some more pics today:
New Fuse Box mounted above the battery (bigger than I expected):
ECM mounted on the passenger side:
New fuel pump installed this afternoon:
And here's something that surprised me---the EROD came with two sets of exhaust manifolds. The engine comes with the Vette manifolds mounted, but the CA Executive Order was for an engine with 2011 Camaro manifolds, so that's what the instructions say to use. I'm not sure how picky the BAR referee is going to be about which manifold is used. The installation instructions do provide some wiggle room:
"Exhaust Manifolds It is recommended that you use the provided
exhaust manifolds or similar LS Engine style Exhaust Manifolds."
Here's the manifold on the engine:
Here's the manifold GM wants us to use:
We'll use the recommended manifold if it fits---the collector is a bit further back than the Vette manifold.
To Erod ls3
Old Mar 16, 2012 | 07:16 PM
  #98
ßill's Avatar
ßill
Looks like a tight fit to the oil filter, can it be remoted?
Old Mar 16, 2012 | 07:44 PM
  #99
3D87C4's Avatar
3D87C4
Don't know. Looks like the Camaro manifolds will make it even tighter, too. I think a sumpless system can be retrofitted into any of the LS engines, but that's not in the swap plan so far.
Old Mar 16, 2012 | 07:54 PM
  #100
ßill's Avatar
ßill
Good luck with the swap. I hope the CARB referee doesn't give you to much trouble.
