What could be smoking?
Old Dec 12, 2011 | 10:30 AM
KLUTZ's Avatar
KLUTZ
Default What could be smoking?
When the '87 project Vette warms up, I start to get "smoke" raising from the rear of the passenger side engine bay. I have new valve cover gaskets on and there is no sign of oil leaking at all. It appears to be originating lower down by the exhaust manifold but with the shield on I can't see. It doesn't have a burning smell like coolant either, nor a smell like burning oil. I saw a Youtube video someone posted that looked like the same scenario but there was no explanation. I also held a piece of paper down to see if the oil pressure sending unit was sending out a fine mist, but nothing either. I can post a video of it if no one has an idea. I just don't want it to burst into flames on me but if it is some liquid just "burning off" it doesn't seem to want to end. Maybe something got in there over the 14 years it sat?
Old Dec 12, 2011 | 10:58 AM
cv67's Avatar
cv67
St. Jude Donor '05
Any stray electrical wires getting singed on something?
Old Dec 12, 2011 | 11:37 AM
KLUTZ's Avatar
KLUTZ
Doubt it. There are no wires in the area it appears to be coming from. And I own MGB's, I know very well,
the smell of singed wiring...
Old Dec 12, 2011 | 12:36 PM
3D87C4's Avatar
3D87C4
Mouse?
Old Dec 12, 2011 | 12:37 PM
joeld's Avatar
joeld
Possibly knock sensor cracked/leaking throwing coolant on exhaust pipe?
Joel
Old Dec 12, 2011 | 01:03 PM
KLUTZ's Avatar
KLUTZ
Joel
Would I not be getting a sweet smell in the vapour (smoke)? There is now odour to it at all.
Old Dec 12, 2011 | 02:05 PM
Frizlefrak's Avatar
Frizlefrak
Check for an oil leak at rear of intake.
Smoke isn't normal. Something is leaking.
Old Dec 12, 2011 | 02:57 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Oil leak on exhaust manifold is the number one possibility. Ogf that is the case, replace the valve covers' gasket.
Old Dec 12, 2011 | 07:06 PM
mazdaverx7's Avatar
mazdaverx7
what does the smoke smell like? does it smell like burning oil or burning antifreeze?
Old Dec 12, 2011 | 07:40 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
just because you replaced the valve cover gasket doesn't mean you don't have a leak. re-torque to bolts. or make sure when you put them on the gasket did not double up
Old Dec 12, 2011 | 08:02 PM
mazdaverx7's Avatar
mazdaverx7
i had to replace my valve cover gaskets twice before i got the leak to stop. ended up using a silicone gasket set. no leaks now.
Old Dec 12, 2011 | 08:16 PM
Frizlefrak's Avatar
Frizlefrak
If you're using cork, replace them with Fel-Pro rubber gaskets.
Old Dec 12, 2011 | 10:02 PM
KLUTZ's Avatar
KLUTZ
I'll re-torque the bolts tomorrow. I did use new Fel-Pro and a gasket sealer as well. I really don't want to have to disconnect the line overtop of the cover again... PITA
Old Dec 12, 2011 | 11:19 PM
Frizlefrak's Avatar
Frizlefrak
You shouldn't need nor use any kind of sealer with the rubber Fel-Pro gaskets. Pull them back off, clean them and the head with acetone, put them back on. I bet your smoke goes away.
Old Dec 13, 2011 | 12:04 AM
popo8's Avatar
popo8
This is where I would check 1st...
Old Dec 13, 2011 | 06:49 AM
Paul Workman's Avatar
Paul Workman
I never saw a SBC that didn't leak sooner or later somewhere along that rear gasket between the block and the intake manifold (among other favorite locations).
A mechanic's mirror on a telescoping stick and a bright light will show you if you have a problem there.
Good hunting!
P.
Old Dec 13, 2011 | 07:33 AM
mazdaverx7's Avatar
mazdaverx7
my favorite is the SBC rear main seal leak.. got a tiny few drops on my garage floor as we speak..
To What could be smoking?
Old Dec 13, 2011 | 12:43 PM
Frizlefrak's Avatar
Frizlefrak
Good hunting!
P.
That's the first place to look.
Old Dec 13, 2011 | 01:08 PM
KLUTZ's Avatar
KLUTZ
And so I shall. Thanks
Old Dec 13, 2011 | 01:24 PM
Frizlefrak's Avatar
Frizlefrak
One of these days, I'm gonna spring for one of those mechanic's cameras that you can snake down into oddball places and see the image on the screen. It would be VERY nice for solving problems like this one. The flashlight and mirror work, but are cumbersome. This gadget would save so many headaches....
http://www.harborfreight.com/digital...era-67979.html
