Antenna ?
Old Dec 21, 2011 | 04:39 PM
GS023's Avatar
GS023
Default Antenna ?
I know there are posts about this already but I can't find one with the exact symptom. On my 96 the antenna is stuck in the up position and can't be forced down. The motor runs for a few seconds when you turn the radio on or off. Will a mast kit fix this?
Thanks in advance.
Old Dec 21, 2011 | 05:20 PM
96BAM's Avatar
96BAM
Had the same on the 96. I just replaced it with a new one. Figured by the time I get it out it would be just as much fun to install a new one.
Old Dec 21, 2011 | 05:35 PM
LTxDave's Avatar
LTxDave
Same symptoms my GS had originally. Replaced the mast and was fine. Much easier to replace the mast than to replace the entire antenna.
Old Dec 21, 2011 | 06:34 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
That is a heck of a fact. That was a PITA.
Old Dec 21, 2011 | 06:39 PM
GS023's Avatar
GS023
I guess 16 years and 148K miles aint too bad. Just ordered a mast kit and will try that first.
Thx
Old Dec 21, 2011 | 06:42 PM
Chuck Tribolet's Avatar
Chuck Tribolet
However, IIRC, '87 and earlier you have to replace the whole unit. I
used a late unit to replace mine.
Old Dec 21, 2011 | 07:19 PM
pcolt94's Avatar
pcolt94
Thanks in advance.
When you get the old antenna out, compare the length to the new one. If it is shorter, then there is a broken piece inside of the motor assemble. In that case you will have to remove the antenna assembly, take it apart and get the pieces out. Then you can install the new mast.
If you don’t get out the broken pieces, it will not work properly.
There is lots of info in the Forum on it. I have done it and many others too.
Old Jan 4, 2012 | 09:06 AM
Da Mail Man's Avatar
Da Mail Man
.....in a previous motor i had, i disassembled the motor unit and found an electrical cam and contact....i noticed that the contact was resting on a worn section of the cam and not making contact...i SLIGHTLY bent the contact and all was fine.......
Old Jan 4, 2012 | 10:25 AM
IAFF alumni's Avatar
IAFF alumni
Same problem with my 92 (stuck in the up position).
When I covered her for the winter, I applied some down pressure and it retracted.
Tried both Zip and Full Throttle Corvette and it seems nobody has the 90-92 antenna assemblies in stock as I was going to just replace the whole assembly.
Anybody know of a parts supplier that might have this part in stock?
Old Jan 4, 2012 | 12:49 PM
mako41's Avatar
mako41
Try some of these suppliers;
www.antennamastsrus.com (Cheapest, No antenna nut tool)
Edit; I asked and they included an AC Delco type antenna mast nut tool free of charge! Great service and an OEM part! Highly recommended!
http://www.amazon.com/ACDelco-125259.../dp/B000S2U596
Old Jan 4, 2012 | 02:28 PM
GS 163's Avatar
GS 163
One of the first things I did when I bought my car was I put an in line switch on the antenna to control when it goes up and down. Small little toggle switch in the compartment behind the passenger seat. Since then, it has never been up. For all I know at this point, it could be stuck in the down position.
Have not had any issues with radio reception. If I do, I just pop in a CD......and yeah, the CD player still works just fine. Although I probably just jinxed myself now.
Old Jan 5, 2012 | 08:35 AM
Donne Trav's Avatar
Donne Trav
I've read on this forum that if there are "broken" bits & pieces inside the
assembly, you have to get inside it to remove the pieces. Isn't the
same task involved --- removing the entire assembly?? Thank you
Old Jan 5, 2012 | 12:47 PM
LTxDave's Avatar
LTxDave
All I had to do was cycle the radio on-off-on and the broken part was sticking up high enough that I could grab it and remove.
To Antenna ?
