Floppy Sunvisor Quick Fix
Old Dec 27, 2011 | 11:39 AM
rmanc69139@aol.com's Avatar
rmanc69139@aol.com
3rd Gear
Default Floppy Sunvisor Quick Fix
If you own a C4 you know how annoying those floppy sunvisor ends are. Well here is a quick fix that looks good, takes less than 5 minutes to do and will cost you less than $5.00.
Buy a length of 1/2" split wire loom (black). Cut two 3" pieces (one for each sunvisor), open the split and slip it over the sunvisor centering it on the weakened score of the sunvisor. And that's it. Still flexible BUT not floppy.
Old Dec 27, 2011 | 12:50 PM
1LOMARO's Avatar
1LOMARO
Sounds like a plan... got some laying around as a matter of fact.
Old Dec 27, 2011 | 03:14 PM
sailorsteve's Avatar
sailorsteve
There was a recent thread from a CF member who took the stainless steel inserts from an old wiper blade and stuck them inside the visor fabric completely where they didn't show. OP's fix is good, too, but this way is likely undetectable.
Old Dec 27, 2011 | 03:19 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Thanks, sailor. I was trying to find that tip not long ago.....
Old Dec 27, 2011 | 03:59 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
I used old vertical blind, someone threw out, cut and works great!
To Floppy Sunvisor Quick Fix
