coil over
Old Dec 29, 2011 | 10:00 PM
yorkfitter's Avatar
yorkfitter
Default coil over
Does anyone have pics and experiece with coil over shocks and does it eliminate the leaf spring. Also where to buy from
Old Dec 30, 2011 | 12:53 AM
jcro61's Avatar
jcro61
Old Dec 30, 2011 | 09:53 AM
yorkfitter's Avatar
yorkfitter
Originally Posted by jcro61
I do not have time to check the forum every day, so how about not saying anything rather than giving your useless 2 cents. I did a search and no helpful info showed up. People ask questions all the time that have been answered before! Thanks.
Old Dec 30, 2011 | 10:30 AM
vettedan's Avatar
vettedan
Van Steel make a nice kit I plane on using for my C4LS1/T56. Gary from Hardbar designed the adapters. Here a link:
http://www.corvette-guru.com/modules...topic_id=13945
Hope this helps,
Danny
Old Dec 30, 2011 | 11:11 AM
miker2's Avatar
miker2
i had a set from drm (doug rippie ) .didn't like them at all for the street. great for road-race course but my particular setup had too quick a rebound in the rear and it rode like a buckboard. wanted to throw you forward. yes,it does away with the leaf spring.
Old Dec 30, 2011 | 01:32 PM
bangbgC6's Avatar
bangbgC6
Originally Posted by c4cruiser
I think the issue is the width of the upper shock mount when using Bilsteins. The early upper mounts are narrower and that shock/spring would probably not fit.
I can't really see how they would be "weaker". There is no real difference in the front lower control arms in terms of area for the lower shock mount ant it looks like the steel bracket for the upper mount is the same thickness compared to later C4's.
One difference in the rear is how the upper shock mount is different. The early cars don't have the separate mounting bracket like the 88 and later C4's.
I looked at the VanSteel website showing the QA1 coilover system (p/n CO-DA-C4 System)and it appears that outside of a pair of HardBar special lower mounting brackets, there is no mention of having to do any custom work. I wonder if it's the same for the Bilstein setup?
This was posted by WVZR-1 on 11/25/11
Maybe he still has them FS
FS - QA1 Coil-Overs "new in box"
These were purchased for a project that I don't believe I'll ever get around to and I need to make some room.
Everything you see here in boxes:
(2) HAL-12-275 275# springs
(4) HAL-SS110SDM Studs for top of all 4 shocks
(2) HAL-DR4855P Shocks
(2) HAL-DR5855P Shocks
(2) HAL-BAR350K T-Bars for front bottom shock mounts
(2) HAL-10-400 400# springs
(1) HAL-T114W spring adjustment tool
I've some additional mounting plates that I believe would make the upper rear install just a bit easier and appear "finished"!
$950 shipped in US - Canada + $35
Good luck
Old Dec 30, 2011 | 03:25 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Check out Exotic Muscle, for your year.
Old Dec 30, 2011 | 07:49 PM
rodj's Avatar
rodj
Look harder
http://forums.corvetteforum.com/c4-t...lover-mod.html
http://forums.corvetteforum.com/c4-t...ck-towers.html
http://forums.corvetteforum.com/c4-t...coilovers.html
Also helps to mention year model when asking ??
To coil over
