LT4 "sys" error code and fix
Old Jan 2, 2012 | 12:31 AM
Sandwich77's Avatar
Sandwich77
Default LT4 "sys" error code and fix
Has anyone encountered this error message on the LT4's before? If so, what was the fix?
Old Jan 2, 2012 | 12:43 AM
Frizlefrak's Avatar
Frizlefrak
Not LT4, but my LT1 did that when the battery was going belly up. New battery solved the problem. Is your charging system working OK?
Old Jan 2, 2012 | 12:46 AM
95 Red Ragtop's Avatar
95 Red Ragtop
New battery fixed mine.
Old Jan 2, 2012 | 01:33 AM
ETM's Avatar
ETM
Check your battery cables as well.
Old Jan 2, 2012 | 07:19 AM
Sandwich77's Avatar
Sandwich77
I'll check, thanks. I have it on a battery tender right now so it could be the problem. I'm not sure of the age of the battery.
Old Jan 2, 2012 | 09:18 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
New battery solved that problem on my LT4.
The owners manual tells you that a flashing SYS may be a problem with your Corvette's electrical system.
In most of those cases, the problem is a low battery.
Old Jan 3, 2012 | 09:36 AM
Sandwich77's Avatar
Sandwich77
Have any of you changed your battery DIY? How hard is it to do?
Old Jan 3, 2012 | 10:24 AM
Frizlefrak's Avatar
Frizlefrak
Loosen the drivers side fender. Torx bolts on the inner fender skirt, and a 10 mm bolt underneath (use a slim open ended wrench). You can then move the fender out of the way far enough for the battery to come out from the side.
Old Jan 3, 2012 | 12:50 PM
Cavi's Avatar
Cavi
also on my LT1 the stereo swap caused the sys message
Old Jan 4, 2012 | 10:39 PM
Eakster's Avatar
Eakster
Same here.. once the Blose is gone apparently any aftermarket system will cause this. There is a solution which involves soldering a resistor into one of the wires.. the info is in the Audio/ Electronics part of the forum.
Old Jan 7, 2012 | 06:11 PM
85vetteguy's Avatar
85vetteguy
low battery
Old Jan 8, 2012 | 09:07 AM
Sandwich77's Avatar
Sandwich77
In light of the battery issue, what do any of you recommend I use, what's worked well for you?
Old Jan 8, 2012 | 09:32 AM
RollaMo-LT4
Just about any top name brand battery will be fine.
Hard to give an example of the "best", as it comes down to personal preference.
Do some searches on batteries, and you'll find plenty of differing opinions.
Here are a few quick searches.
http://forums.corvetteforum.com/c4-g...iven-much.html
http://forums.corvetteforum.com/c4-t...t-battery.html
http://forums.corvetteforum.com/c4-g...n-battery.html
To LT4 "sys" error code and fix
