Need info on ABS sensor wiring
Old Jan 14, 2012 | 11:53 PM
3313-C4's Avatar
3313-C4
2nd Gear
Default Need info on ABS sensor wiring
Are there any sources for the wiring for the ABS wheel sensors? My wires are ok but the insulation (Rubber?) has crumbled off.
How much hassle to replace? Our C4 is a one owner 1987 coupe. It's low in miles but not in age so I guess that's what happened to the rubber.
Thanks,
Judy
Old Jan 15, 2012 | 04:11 PM
3D-Aircrew's Avatar
3D-Aircrew
Default 86 with same issue
Thanks,
Judy
Mine too
Old Jan 15, 2012 | 04:59 PM
sailorsteve's Avatar
sailorsteve
Have you tried any of the Forum vendors listed in the left-side column?
Old Jan 15, 2012 | 05:50 PM
3313-C4's Avatar
3313-C4
2nd Gear
Yes, Searched the non-dealers who handle C4 parts for ABS Wiring. Searched almost all for "how to" in order to answer the 2nd part of my question.
Will drive to a local dealer during the week when they are open. Thought I might get some insight on the forum while I was waiting.....
Judy
Old Jan 16, 2012 | 02:21 AM
wayne smith's Avatar
wayne smith
Maybe you could try putting some heat shrink over them or split electrical conduit
Old Jan 16, 2012 | 01:08 PM
sailorsteve
Judy
Just tried a Google search for 1987+Corvette+wiring+abs and found some vendors. Seems they are common to other GM vehicles. Use the + between the words to narrow the search. You could also try www.rockauto.com.
Old Jan 24, 2012 | 03:07 AM
Cliff Harris's Avatar
Cliff Harris
I have the same situation on my '86: wires OK, sleeving got brittle and crumbled. I bought used sensors from a vendor on eBay but the idiot just cut the wires, so I didn't get the connectors. My plan was to rewire them (I "borrowed" some teflon wire from work), but I can't do that without the connectors. I haven't figured out what to use for sleeving yet, so that project is on hold.
I think they went to better sleeving in later years because I have checked with friends and their sleeving is OK. I don't know if later ABS sensors will just plug in without a problem. The Bosch part number is molded into the sensor but that number is also unavailable.
To Need info on ABS sensor wiring
