Orbital Buffer Use?
Old May 13, 2002 | 02:41 AM
n1kki6's Avatar
n1kki6
Default Orbital Buffer Use?
I have a motorized buffer that i was thinking about using on my vette and was wondering if there is anything i should know before i do, or if i should just take the wax off by hand.
Old May 13, 2002 | 08:52 AM
JonM's Avatar
JonM
Default Re: Orbital Buffer Use? (n1kki6)
:nono: Just as Joan Crawford says "No Wire Hangers" you should never use mecanical buffers on your Corvette. If you want to take the wax off your car, wash it a couple times with Dawn dish soap
Old May 13, 2002 | 01:13 PM
Square's Avatar
Square
Default Re: Orbital Buffer Use? (JonM)
I was visiting a Chevy Dealer in Raleigh, NC this weekend, and they had 3 2001's they were selling right next to their new 2002 models. Someone had gone "buffer crazy" on those 2001's and the swirl marks were unbelieveable! :eek: They had a 2001 Z06 that was covered in swirl marks! Enough to make you cry! Personnaly, I would stay away from a mechanical buffer, and stick to pure 100% cotton cloths and a soft hand touch. :seeya :chevy
Old May 13, 2002 | 06:13 PM
Dolfan's Avatar
Dolfan
Default Re: Orbital Buffer Use? (Square)
While I understand these comments, how do you treat a paint job that has a final wet sand using something like a 1000 grit to smooth paint imperfections. We always used to use a buffer for jobs like this to restore the shine after sanding. This was usually laquer based finishes and not on vettes?
Old May 13, 2002 | 06:33 PM
blk90rdstr's Avatar
blk90rdstr
Default Re: Orbital Buffer Use? (Dolfan)
Youre talking a different process than a routine waxing. In extreme circumstances like after wetsanding or in restoring neglegted paint a machine buffing with a buffer (not an orbital) is necessary, and there are steps to take after buffing to remove the swirls. When the paint is already good, hand application of waxes/ polishes is best. :D
Old May 13, 2002 | 07:23 PM
Airborne's Avatar
Airborne
Buffer use should be approached very C A R E F U L L Y especialy along the body ridges and edges. Most of my experience (and that of many in the Car Care section) has shown better results without a buffer. Lots of good products available.
Plus, I'd second the DAWN dish soap idea for wax removal. :)
Old May 13, 2002 | 08:16 PM
Thomas's Avatar
Thomas
Ummmmmmm Dawn will NOT remove any silicone based wax. It will not remove Zaino either.
Dont TOUCH your paint with a direct drive buffer. ORBITAL ONLY!!!!!!
[Modified by Thomas, 6:17 PM 5/13/2002]
[Modified by Thomas, 6:18 PM 5/13/2002]
Old May 13, 2002 | 10:40 PM
stockred96's Avatar
stockred96
Default Re: Orbital Buffer Use? (Thomas)
I use the orbital to put liquid wax on...it does a great job of getting the wax down even. Once dry I take the wax off by hand.
Old May 14, 2002 | 01:28 AM
Airborne's Avatar
Airborne
No, but alchohol will. :)
Old May 14, 2002 | 06:27 PM
Thomas's Avatar
Thomas
Default Re: Orbital Buffer Use? (Airborne)
You are correct sir!! IP alchohol
Old May 14, 2002 | 09:30 PM
Wadoka's Avatar
Wadoka
St. Jude Donor '03-'04
Cruise-In 1-2-3-4-5 Veteran
Actually, even the alcohol takes forever to remove the Zaino. That is truly tenacious stuff.
And the Porter-Cable random orbital buffer with 6" foam pads is a beautiful piece of work. I've been using mine one panel at a time on my black '93, with fine swirl mark remover, and the car looks incredibly better. Any further improvement, unfortunately, requires a new paint job...
As long as you use low RPMs, a foam pad, fine-cut polish, and never, ever let your pad pick up dust and grit from anything else, you'll be fine. But don't polish until the car is absolutely clean and clayed. Then clean it again.
Old May 14, 2002 | 09:54 PM
Thomas's Avatar
Thomas
Default Re: Orbital Buffer Use? (Matt Black)
I have the Porter Cable also. Using it with GREAT results,,,,,,,,,,
Old May 14, 2002 | 10:38 PM
IMXCITD's Avatar
IMXCITD
Best use for that orbital buffer is to keep it in the closet! If not..you will be sorry. :)
Old May 14, 2002 | 11:38 PM
Thomas's Avatar
Thomas
Default Re: Orbital Buffer Use? (IMXCITD)
And why is this? I have been using it and the results are great?
Old May 15, 2002 | 02:09 AM
Airborne's Avatar
Airborne
I'm cuttin' Thomas some slack on this one. There are some beautiful "buffed" Vettes I've seen at the Show & Shines. It no doubt is just like any other detailing work except that in the wrong hands damage is a distinct possibility. :(
It's just that there are so many examples out there of what NOT to do.
One other thing re Zaino. The stuff (great as it is) is almost impossible to remove from pebbled plastic body moulding found on many Sport Utes. :cheers:
Old May 15, 2002 | 10:52 AM
Thomas's Avatar
Thomas
In THEORY, you should only have to polish the car one time, to remove the small scratches/swirls. With a little care, a person should not be putting them back into the car.
Old May 15, 2002 | 11:41 AM
luvmy92's Avatar
luvmy92
I have been using a low-speed orbital for years and wouldn't use anything else. Mine is of the 9" variety and as far as I can recall, I have never seen a swirl mark on the car. Granted, I only use the buffer to apply polish and wax, and never to remove it. I do that by hand. Also, I only use Maguiers products. Have thought of trying Zaino but really don't have the need...
Mike
Old May 15, 2002 | 01:50 PM
Mystic '95's Avatar
Mystic '95
Cruise-In II Veteran
Default Re: Orbital Buffer Use? (luvmy92)
A little trick I learned from a pro when using an orbital. (when removing)
The buffing pad after a 'short' while gets caked with wax and little particulates that it picks up along the way thus causing scratches and swirls.
Take a 'small' 100% cotton towel and place it between your pad and the finish,
the towel will rotate very slowly and since it's larger than the pad, you can turn it frequently and shake it out. The buffer pad never touches the car. On verticle surfaces, just hold the towel and place the buffer against it, it won't fly.
I have no buffer marks. As far as taking off by hand, this is fine but I find that we mere humans are not able to maintain an even pressure, sometimes we press down harder causing marks as well.
BTW: I'm a Zainoholic, I wax and buff mine 6~10 times a month, thanks to ZFX... :cheers: :seeya
To Orbital Buffer Use?
