Headlight Issue
Old Feb 2, 2012 | 05:13 PM
DaleLentz's Avatar
DaleLentz
Cruising
Default Headlight Issue
Howdy folks. Me again. OLD, Slow, not mechanically inclinded. FIRST: HeadLight (passenger side) won't go all the way up. I will get fixed, HOWEVER, for today I need to manually Open the headlights so I can use them in the car in the early morning. I opened and it worked fine but as soon as I turned off the ignition, they both went down again.
I was told to remove two wires from the connectors, but which ones was not mentioned.
Sure could use some help. Yes, I ahve been ready the DIY section but replaceing gears is all I've found.
Any help would surely be appreciated
Dale
Old Feb 2, 2012 | 05:30 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
You should be able to locate the electrical connector to each HL motor, those would be the connections to remove.
Old Feb 2, 2012 | 05:33 PM
DaleLentz's Avatar
DaleLentz
Cruising
Thank You for the reply. I did that, but then the headlights do not work.
I was told that in the 5 wires of the connectors, two of them control the opening and closing of the headlight assembly. I just don't know which ones.
If someone knows which ones to disconnect, it might save me from destroying the whole system.
Cheers
Dale
Old Feb 2, 2012 | 06:44 PM
Chuck Tribolet's Avatar
Chuck Tribolet
What year is your 'vette?
Chuck
Old Feb 3, 2012 | 07:18 AM
DaleLentz's Avatar
DaleLentz
Cruising
Howdy Chuck
Sorry I've been so stupid. Old age is hell. I have a 95 base coupe.
I may have to do the old pull one plug at a time trick.
To Headlight Issue
