U Joint Procedure
Old Feb 11, 2012 | 06:12 PM
J W Drew's Avatar
J W Drew
Default U Joint Procedure
Can someone explain the procedure to change the U Joint(s)? on my 85 Vette. Reg suspension. Clunks when I go to reverse or drive. Classic feeling I had in the past with other cars with worn joints. Could be Trans?
Old Feb 11, 2012 | 06:28 PM
blackbear bob's Avatar
blackbear bob
do a search for "washers" and be sure that you have new ones when you do the job.
Bob
Old Feb 11, 2012 | 07:01 PM
vetteoz's Avatar
vetteoz
http://personal.tmlp.com/scorp/vette/images/ujoints/
Old Feb 11, 2012 | 08:25 PM
mike100's Avatar
mike100
tighten the axle nut first and see if it gets better. not saying you don't need universals, but they are not always the source of the 'clunk'.
Old Feb 11, 2012 | 08:43 PM
vetteoz's Avatar
vetteoz
Rust on the splines between hub and yoke has also been previously mentioned
Old Feb 11, 2012 | 11:29 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
This is an excellent proceedure. We used it last weekend to replace the u-joints on both half shafts of the 95.
But several years ago when I had the "clunk" when going into reverse and into drive .... it was the washer that solved that particular issue.
Old Feb 12, 2012 | 03:01 AM
Wathen1955's Avatar
Wathen1955
Hum...on my 96, I've been noticing a similar noise, but its more of a tinging sound instead of a clunking sound. Would that be u-joints as well?
Old Feb 12, 2012 | 08:57 AM
Joe C's Avatar
Joe C
Bob
OK, i give up - what "washers" are you talking about? i don't recall replacing any washers when i did u-joints - ???
To U Joint Procedure
