Weird Engine issue
Old Feb 14, 2012 | 12:28 AM
kdtomczak's Avatar
kdtomczak
Default Weird Engine issue
In my 86, sometimes when i'm at a stop light or in park, my engine will feel like someone's pressing the pedal in a rhythm. The car will even try to pull forward while I'm holding the brake..
Anyone know what could be causing this?
Old Feb 14, 2012 | 07:49 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
You might want to start with looking for a vacuum leak.
Old Feb 14, 2012 | 09:38 AM
Goldcylon's Avatar
Goldcylon
Throttle adjustment ?
Old Feb 15, 2012 | 07:27 AM
Keystring's Avatar
Keystring
Besides the suggestions above, you could also either have a bad Throttle Position Sensor or a dirty MAF sensor. (I think 85 is MAF and not MAP).
Old Feb 15, 2012 | 01:38 PM
BroCorvette's Avatar
BroCorvette
Correct 85' is MAF only.
Old Feb 15, 2012 | 01:50 PM
383vett's Avatar
383vett
Does your car have a roots blower and dual carbs?
Old Feb 15, 2012 | 06:51 PM
John A. Marker's Avatar
John A. Marker
Check TPS and then the AIC. It could be that the AIC passage has carbon build up.
I would think that if you had vacuum leaks the problem would be more constant.
Old Feb 15, 2012 | 07:24 PM
SunCr's Avatar
SunCr
ECM may be trying to compensate for some load that doesn't exist and that's usually a/c or if an Auto, a neutral/drive signal. With either input, the ECM increases/decreases IAC counts and pulse width to maintain whatever is targeted for idle speed. If you hook up a scanner, you can look at the data stream and find out if there's any signal that shouldn't be there. Note if it is a/c - these early years aren't perfect in matching compressor load to idle speed and you can often feel the load of the compressor as it cycles, though it shouldn't be severe enough that you need to stomp on the brakes to keep it from moving forward. If the condition is intermittent, that may be all that's happening, as compressor cycling depends on ambient air temp and charge. If you can get the data, you should be able to figure it out.
To Weird Engine issue
