Bummer bro... Are you doing the repair or are you taking it somewhere?
I did a semi zip tie patch =\ not the same I know it's there. I was thinking of buying a new set for both sides cause they are scratched up (live down a rocky road) but if I have to take it somewhere I will i suppose
I bought one from a forum member and it had it painted total cost was $100. It was very easy to replace, just some bolts and one hidden behind either the rear or front inner wheel well...I think it was the rear, other than a very east part to replace...
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Yep, the hidden one is behind the rear inner fender.
Had mine off for something I was doing and thats where I found the hidden hex head screw.
