tire size
Old Feb 27, 2012 | 04:48 PM
Cavi's Avatar
Cavi
Default tire size
What size tires are you all running on the rear of your car, I know it depends on your wheel size, so please state that. What I am wanting to find out is ultimitly the total tire diameter.
My car is running C5 wheels which means my rear wheel is a 9.5 X 18 inch. I am runnig 275/40/18 which has a diamiter of around 26.5 inches. I seem to see other vettes with either 275/40/17 or 285/40/17 on the rear, those would yield 25.7 to 25.9 inches Ultimitly this means I am running too large of a tire by betwen half and inch to 1 inch. I need to buy new tires for autox and if I go with 274/35/18 I would be at 25.7 which I am guessing would be closer to stock. The plus is more quick off the line, the negative is the gap from tire to body will increase which is ugly.
Anyway just wanting to confirm what most are running to see it my figures make sense.
Old Feb 27, 2012 | 08:25 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
I would go with a 285/35-18 which is approx. 25.85"
The factory 285/40-17 on my '96 is approx. 25.98"
The 285/35 will get you back to very close to the factory specs.
And that tire will fit on you current 9.5" rim.
Old Feb 29, 2012 | 11:29 AM
Nathan Plemons's Avatar
Nathan Plemons
If you're serious about auto-x you may want to consider matching sizes front to rear.
In 93 they changed to a narrower tire up front and then offered a "performance handling" package that included the same size.
Old Feb 29, 2012 | 11:39 AM
Cavi's Avatar
Cavi
Already done, I have 4 rear C5 wagon wheels, I already had 2 and I found 2 more so I will run 275 all around!!
Old Feb 29, 2012 | 11:43 AM
Nathan Plemons
I wonder if anybody knows what is the biggest tire you can run up front without it sticking out and running stupid. Seems like you might squeeze a 285 up there.
Old Feb 29, 2012 | 11:49 AM
Cavi's Avatar
Cavi
I picked up a half life set of R compounds already in 275/35/18!!
Old Feb 29, 2012 | 11:50 AM
Nathan Plemons
Well there yah go. You'll like the change in the handling.
Old Feb 29, 2012 | 12:26 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
That is the perfect size for those wheels.
To tire size
