Headlight ISSUE
Old Feb 28, 2012 | 12:43 AM
kdtomczak's Avatar
kdtomczak
Default Headlight ISSUE
My left headlight stopped working a few days ago. I got a new motor for it and new wire connections from the motor to the car connection.
When I plugged in the motor, the newly installed headlight turned outwards (in the on position) immediately while the other one stayed turned off. When I pulled the headlight switch out to turn the other one on, it came on so both headlights were on. Then when I went to turn them off, the new one stayed on.
When I would manually put it back in...about halfway it would turn back on.
Any suggestions?
Old Feb 28, 2012 | 01:30 AM
oldalaskaman's Avatar
oldalaskaman
use the adjustment ***** and match them up
Old Feb 28, 2012 | 01:49 AM
kdtomczak's Avatar
kdtomczak
I did that. Its random when it decides to move, but the connection from the new motor is brand new from ecklers and the car connection are shielded.
Old Feb 28, 2012 | 02:24 AM
oldalaskaman
what year is your car?
Old Feb 28, 2012 | 12:40 PM
kdtomczak's Avatar
kdtomczak
Old Feb 28, 2012 | 01:59 PM
oldalaskaman
un-plug the new one , activate the old one, disconnect your battery and then match the new to the old. after that it gets more complicated
To Headlight ISSUE
